Results 1 to 17 of 17
Thread: vt clutch/flywheel
    vt II spac manual
    Oct 2007
    mornington
    Default vt clutch/flywheel
    hey guys i think the clutch/flywheel in my vt has gone
    whenever i put my foot down the revs go through the roof and the car goes nowhere....i think this means the clutch is "slipping"?
    if so how much is reasonable to pay for a new clutch???
    is it worth goin heavy duty or not?
    thanks for any help
    p.s i got quoted 2180$$$ 2 get a new clutch and flywheel for it...seems bloody expensive 2 me
    vz wagon
    Aug 2006
    Wild west of Melb
    Quote Originally Posted by vt_s_manual View Post
    thanks for any help
    Try just a clutch and pressure plate the flywheel wont need replacing maybe a machine but it shouldent need replacing that will get ya price down as for heavy duty it all depends what you plan doin in the car.
    A Pushie
    Mar 2006
    Cronulla, NSW
    For a v6 from memory a standard duty clutch is around $800, you shouldn't need a new flywheel, if you do, then you can get clutch/flywheel packages for around $1000.
    It's not over $1000 worth of labor. In a shop it'd be around 4 or 5 hours labour maximum.
    I replaced my flywheel and clutch on my v8 in a day between a case of beer and no experience ever going it, while it was just on car stands. Shop around, it sounds like this bloke is definitely trying to rip you off.
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    Before changing the clutch, check that the clutch pedal doesn't need adjusting.
    That was my mistake. For some reason my clutch pedal adjustment didn't have a locking nut and kept readjusting itself.
    Only discovered this after I changed the clutch
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    i work at repco and i can tell you now
    for a brand new standard clutch and flywheel package you are looking at 2000
    SMIT's Avatar
    Aug 2005
    VE ss ute hopefully, or ss-v
    Oct 2006
    what we have here boys, is what us mechanics call a dual mass flywheel. i can't beleive someone else hasn't picked up on it yet. i'm not gunna explain it, pbr will do it quicker and shorter than i can. but basically all the clutch dampining when u release the pedal slow from a stop (i.e great difference of engine rpm, and input shaft of gearbox rpm) comes from the dual mass with this sort of clutch. if yours is a v6 (which going off ur ride section-vt s pack series 2 manual) u have a getrag gearbox, and all getrag gearboxes have a dual mass flywheel which requires replacement with clutch replacement.
    shop around, for a exedy sports tuff clutch (not a button clutch, but a strong clutch) i paid 1300, with spigot bush and new solid steel replacement flywheel. (so if the clutch ever gets replaced again, because of the solid flywheel, it doesn't need replacing)
    hang on a sec, and i'll find the information page on dual mass flywheels so you can see how they work, why they are used etc etc.
    my price of 1300, was trade price. so expect a little higher. expect 1450 or so for a exedy sports tuff clutch and flywheel and throw out bearing and spigot bush, plus labour for fitting. might as well get a tougher clutch, only ever usually cost's $80 or so more.
    generally also, hydraulic clutch's can't/shouldn't be adjusted. you can adjust the puishrod of the clutch master cylinder, but your best to replace the clutch, as adjusting that isn't a good idea. needing to adjuist is shows ur clutch is getting weaker and weaker.
    peter brock once a legend, always a legend, mate you will never be forgotten
    Bite off more than you can chew, then chew like hell - Peter Brock RIP
    Oct 2006
    http://www.aftermarketnews.com/defau...Text&item=5202
    basic explanation of dual mass flywheel, sorta doesn't cover our austrlian setup's 100% but i couldn't find the page on the exedy site i was looking for. anyway give me rep if its helped
    Jan 2008
    also take note that dual mass flywheels cant be machined because they have a floating face, if you dont replace the flywheel you run the risk of shudder when you fit the replacement clutch. std clutch & fwheel is around $1500 trade.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    A few people beat me to it...
    You got a POS musshy cushy dual mass flywheel which is great if your a sucky driver and can't shift properly as it eases the jerking...
    Once the clutch is gone you can be sure the flywheel is also r**ted.
    I replaced my clutch and machined the flywheel when my clutch died in my old car the first time round... that lasted a year before it was slipping like a lathered monkey down a slippery dip.
    DON"T get a factory kit back in there... expensive and cr*p overall.
    Get something better like a Exedy HD kit.
    I picked mine up for $1300 and had it installed for another 300 odd.... amazing!
    Now you will go to repco, autobarn, supercheap and they will tell you anything between 1450 - 1800 for this kit!
    I got mine through an ebay seller... they where called "brakesclutch" but i dunno if they are still up there....
    Best bet is to first use any contacts you got and see what deal u can tee up, then jump on ebay n have a shop.
    Exedy HD clutch part number: GMK-7353HDFW
    Ring around, shop around and you will save heaps!
    Good Luck
    VZ AWD One Tonner
    Jul 2006
    Yes, has as been said, far and away the best option is to replace the existing factory dual mass flywheel (if it already hasn't been) with a solid aftermarket one with exedy heavy duty cluch.
    As has been said, RRP and trade are about $2000 and $1500 respectively, but they can be had cheaper...
    GMK-7353FW $1240 and the heavy duty GMK-7353HDFW $1296. Both in stock.
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    A Pushie
    Mar 2006
    Cronulla, NSW
    Quote Originally Posted by kinkbike_rider View Post
    This is why I don't shop at repco
    VZ AWD One Tonner
    Jul 2006
    That's putting it nicely!
    5 speed VX S-pack Series 2
    Mar 2007
    Anyone know if theres any difference in the idle of the car with the heavy duty compared to dual mass and also with my car sitting in 5th at 100km/h its reving only at 2100rpm would it be lower or higher with the heavy duty ?
  15. #15
    VZ AWD One Tonner
    Jul 2006
    Would be exactly the same... your clutch doesn't change your gear ratios!?!? Only in an automatic can that happen...
  16. #16
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
  17. #17
    MY10 VE SS-V wagon
    May 2005
    thanks for any help
    your not alone getting mine done $1900 for genuine VX clutch kit and flywheel supply / fitted / labor
    Got three quotes and Holden dealership was the cheapest - only by $50-$150
    2 years warranty / 50,000 kms for genuine parts - I can live with that
  1. New Exedy HD clutch and rigid flywheel installed
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2007, 07:15 AM
  2. Exedy HD Clutch and Flywheel kit
    Last Post: 31-01-2007, 03:45 PM
  3. VL turbo clutch, flywheel and pressure plate [VIC]
    By be_inspyred in forum Parts And Other Items For Sale
    Last Post: 23-02-2006, 01:40 PM
  4. flywheel and clutch
    By bommodore in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-09-2005, 08:39 PM
  5. Vk Flywheel
    By LeonH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-03-2004, 08:22 PM
