| VT - VX Holden Commodore (1997 - 2002) Talk about anything relating to the VT - VX Holden Commodore. |
07-01-2008, 08:06 AM
Ride: '97 VT ecotec
Lsd?
so if u jack ur rear wheels off the ground and turn a wheel the other one should spin , right , but in the opperset direction ?? and is LS standard in the VT s1?
07-01-2008, 08:47 AM
No longer mooching...
Ride: e30 318i manual
Yeah it should spin opposite
No its not standard i don't think
Only in the SS and super6 i think
__________________
 Sarcasm, ignorance arrogance FTW!
07-01-2008, 03:45 PM
Ride: VT EXECUTIVE
Poilce cars have them too.
07-01-2008, 04:04 PM
Stiff nips 4 jew
Ride: '92 HSV VP GTS
This is from VN_Luke's thread:
* Jack up the rear of your car so both rear wheels are in the air.
* Make sure the car is supported safely and the front wheels chocked.
* Place the car in neutral with the handbrake off.
* Turn one of the rear wheels as if the car is driving forward. If the other wheel turns the same way, chances are you have an LSD - If the other wheel turns the opposite way, chances are you have an open diff.
__________________
Build 018/130 14.6 Sec Sex Machine If its got WHEELS or TITS it'll give you the Sheets! Ban LOW Performance Drivers, NOT High Performance Cars.
07-01-2008, 04:08 PM
Ride: A Pushie
The lsd was optional in the S pack, calais and berlina from memory as well.
07-01-2008, 04:16 PM
Morgage. **** Wrong Again
Ride: 2000 VT II Berlina V6
What happens if you turn a roundabout and as you are almost straight you powerslide? Is this LSD or like some IRS i have seen they hook both up when weight shifts? Or is that LSD?.
07-01-2008, 04:42 PM
Ride: 2000 VX Calais 3.8L Supercharged
look at ur ID plate, should tell u all u need
07-01-2008, 04:54 PM
For external use only
Ride: 5sp VQ Statesman 5.0
An open diff which has been thrashed to hell and back, can begin to fault and will spin both wheels from time to time. It is also possible to have an open diff spin both wheels if the balance of traction between two wheels is just right.
Oh, and you can powerslide out of a roundabout with both an open diff and LSD
__________________
The V8 Manual VQ Statesman
Traction courtesy of Highway Max™ tyres.
07-01-2008, 06:07 PM
Ride: '97 VT ecotec
ah ok cheers guys , any ideas on how much an LS diff center woudly cost roughly?
07-01-2008, 06:30 PM
Quote:
I'm thinking something fishy about it... The cradle looks changed so i think something was done iunder it.
Same roundabout in the VP will just spin up the road straight, But the VT   I like it though  .
07-01-2008, 09:37 PM
Ride: VT SS 5.0
An LSD Diff will have a little metal tag on the diff that says 3.07 LSD (for auto). It is on the bolt you empty the oil out of.
08-01-2008, 12:34 AM
I'm going to have to wait till it's getting the tyres done then sneak under and have a look, My guts wont get under it on the ground  .
08-01-2008, 08:54 PM
supercheap team member
Ride: 02 VU 3.8L Manny
Quote:
or high performance lubricant required...meaning u need to put synthetic oil in it and there fore u get to spin 2 wheels like me
__________________
Check out my ride here... VUV6
 If i was helpful please click on scales up the top and give me sum feedback!
08-01-2008, 09:23 PM
Ride: VT Calais 5.0L
Quote:
Not sure for just the centre, but new LSD , New Gears , New Bearings, full rebuild cost me $1500. Best to change the gears from 3.07 to atleast 3.45 if you are going to be bothered changing to LSD.
