Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VT - VX Holden Commodore (1997 - 2002)
VT - VX Holden Commodore (1997 - 2002) Talk about anything relating to the VT - VX Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 07-01-2008, 01:04 PM
Noy's Avatar
Noy Noy is online now
Ride: VN SS 5.0
Trade Rating: (0)
Noy Executive
Default VT Fuel Filter remove?
Ay guys im having trouble removing my fuel filter from my VT, I press in the 2 clips, press on it, but doesnt release? is there like a tool for it?
Any help appreciated
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 07-01-2008, 01:08 PM
Not_An_Abba_Fan's Avatar
Ride: MY08 Outlander XLS
Trade Rating: (0)
Not_An_Abba_Fan GrangeNot_An_Abba_Fan GrangeNot_An_Abba_Fan Grange
If there is pressure in the line it can be a bugger to get off. But just wiggle it a bit and it should come off.
__________________
It is better to be silent and thought a fool than to open your mouth and prove it.
Quote:
Originally Posted by DannyboyDS View Post
Wholesaler of exhaust, suspension and brakes.
  #3
Old 07-01-2008, 01:14 PM
Noy's Avatar
Ride: VN SS 5.0
Trade Rating: (0)
Noy Executive
I removed my fuel pump relay, but yeah probably still presssure in it. Will try again!
  #4
Old 07-01-2008, 02:04 PM
accentstencil's Avatar
Donating Member
Ride: WH II Caprice, 5.7
accentstencil Caprice
Push hose forward towards the filter, then press the clips and then pull. You may need to pull hard (the hose that is)
__________________
  #5
Old 07-01-2008, 09:41 PM
Ride: VT SS 5.0
Trade Rating: (0)
Trewman has disabled reputation
Those clips are a bastard. I ended up cutting them and using normal clamps on it.
  #6
Old 07-01-2008, 10:02 PM
Noy's Avatar
Ride: VN SS 5.0
Trade Rating: (0)
Noy Executive
Thanks luke, I might end up doing that lol.
  #7
Old 07-01-2008, 10:42 PM
daron's Avatar
Ride: vt 2000 series 2
Trade Rating: (0)
daron Berlina
spray with wd40 wigle clips in and out a few times they will come off easy
once ya done it once youll be glad ya didnt cut and shut
__________________
stay tuned for next cruise here
never drive faster than your guardian angel can fly
  #8
Old 08-01-2008, 07:04 AM
Ride: vt commodore S
xx1600xx Executive
hay mate, NO dont cut your clips, just push the clips together, you will notice a little bit of plastic on it that is bumpy, or ribbed, push the plugs hard together, with your fingers, squeeze the plug and the ribbed bit tite, and then give it a pull and it should just come apart easy as that!!!!! but you have to squeeze the plug tight the whole time. if it doesnt work, keep trying, coz it will. it realy not hard at all
  #9
Old 08-01-2008, 08:29 PM
Noy's Avatar
Ride: VN SS 5.0
Trade Rating: (0)
Noy Executive
Yeah I knew what to do, just couldnt get it off. Though eventually got it out.
  #10
Old 06-04-2008, 11:06 AM
savage1987's Avatar
Donating Member
Ride: 1989 VN V6, 1994 VR SS BT1
savage1987 Calais
What a pain. Going through this now in a VX. I can't believe they didn't just use hose clamps like every other model ever!
Sam
__________________
My VR BT1 5L: http://forums.justcommodores.com.au/...-bt1-pack.html
My VN series 1 V6: http://forums.justcommodores.com.au/...-vn-s1-v6.html
WTB: GENUINE VN SS KIT
WTB [Perth]: VN minispooled live rear axle complete
  #11
Old 06-04-2008, 11:57 AM
Ride: VY SII HBD Calais L67
Trade Rating: (0)
chargedvx6 Executive
The trick is to push the whole clip against the fuel filter body 1stn then the clips have more room to move. Than you just slide the clip off.
  #12
Old 07-04-2008, 12:30 PM
savage1987's Avatar
Donating Member
savage1987 Calais
Yeah I got it straight away after reading this thread. It's just confusing to look at, not knowing how you're even meant to approach it. I tried a few things gently beforehand and ended up snapping a tiny bit off one side, nothing damaging just a pointless bit. I got annoyed, came inside, searched the forums and read this, it was so simple
Sam
__________________
  #13
Old 07-04-2008, 06:16 PM
only milk comes in 2litrs
Ride: vt exec on 20s
Trade Rating: (0)
vt_on_20s Executive
if you want to get rid of the pressure take out the fuel pump relay then start the car till it dies then take it off. but the pressure shouldn't be the problem EVER!.... also savage1987 just a question? how many cars have you seen with normal hose clamps on them? cause i haven't seen many at all? do you mean normal clamps as in like heater hose clamps where you use a screw driver or socket to get off?/???
  #14
Old 07-04-2008, 06:30 PM
Ride: N/A
Trade Rating: (0)
SSbeast Executive
I've got a VX SS same fuel filter setup, but when i went to disconnect it fuel poured out. Does anyone know how much fuel should come out? I did de-pressurise but i had a full tank. I thought mabye it was being gravity feed and was going to drain the tank so i gave up after awhile.
