hey guys bit of a problem turned on my ac dis morning and worked fine turned on dis arvo and nothing no air nothing wat could cause this blown fuse or wat if any one can help dat would be great i guess its old skool windows for awhile![]()
yeah the exact same thing happened to me today. The a/c was working fine this morning, then on the way home from work, the fan stopped suddenly, then went again, a/c was full blast, then the whole fan system inside thecar just stopped completely.
I pulled up and checked all fuses/relays, inside and out and everything was fine, but another thing i noticed was that both thermofans on the radiator had stopped working completely.
Can anyone give me an idea on what may ave caused this and how to fix it... I just hope its something simple.
Start by checking fuses and relays for the blower and A/C.
MY RIDE
Ok I really know nothing about this but will explain as best I can..... LMAO
My air cond in my VX was working fine, then suddenly stopped, near no air coming out, So hubby found a thread on here somewhere done up by another member, something about there being a ****load of dust on the fan (behind the glovebox I assume) he got the fan out, cleaned it and my air cond has been perfect since. I tried to find the thread again but cant seem to. But since your thermo fans have stopped too, perhaps completely different issue.....
Speaking of Thermo fans, only 1 of mine work. Dunno why though, so will keep an eye on this maybe there is more to it.
that thought occurred to me, i'll have to check it, but i dont think its the only issue, because it stopped suddenly, then went again, ten completely died.
as far as i know, i think only one thermofan is supposed to contantly be in use, and i think the 2nd one only kicks when as required.
Oh good my car isnt broken then lol
Thats what mine did though, it did it a few times, I would turn it off and on then change the settings and it would work for a while then stop again.
ok, well its worth a look, ill go check and see what happens, but if thees any other suggestions let me know.
i removed the fan and checked it, i think its fine, but it wasnt dirty or anything, and was not the cause of the problem. The thermo fans are still not going so i duno what to do??
problem solved. turns out the the bushes in the fan motor needed a good thorough cleaning up, there was also a screw loose in there from something, so it was removed. Fan motor generally got a service for $60 and it solved the problem.
