hammer and scrwsdriver and gently tap it round and off
spray lube/wd40 will loosen it
Ay guys I finally have dropped my tank, though im stuck on other hertal.
I cant remove the fuel pump/sender. I have tryd screw driver + hammer, multi-grips though just doesnt want to budge an inch. I have read there is a special tool to remove this, do you guys know how much it cost to buy this "special tool"
Or how did you get it to come out?
Thanks guys, this hole process is just a pain lol
Yeah, I ended up getting it out today, with a screw driver and hammer.
I just dont have patients lol.
Thanks daron though, your always answering my questions![]()
heheehhe
i feel like im always 1 step ahead of your mods and done them just b4 you get to them so i can help ya out![]()
Can the pump be removed with out taking out the tank ?
No because the sender is on the top of the tank
They are at the back, I found that if I jacked up just the car, not under the diff, you can get enough clearance to pull the pump out.
