With my VX i had to get different looms because the slots on the monaro lights to fit them were different. $10-$20 off ebay.
To remove and fit the tailights, u gotta undo the black plastic piece at the back of the boot, the whole section that surrounds the boot latch.
There will be 4 screws along the top of the plastic piece, plus one either side, behind the lights. Undo these and pop the plastic over the boot latch towards the front of the car.
Pull back the boot carpet so you can see the looms, you can unplug them if u need to change them.
To get the lights out, undo the two screws on the inside of each light, you can see them they stand out like dogs balls, the boot covers them when shut.
once the screws are undone, u gotta try n wiggle the lights towards the front of the car and outward, so the clips holding them in at the front of each light pop out ok.
Once u get em out u can undo the globed and push the rubber grommet thru the hole to get it out if they need to be changed.
