Results 1 to 15 of 15
Thread: Quick question regarding air-con vents
    *VOLATILE*'s Avatar
    *VOLATILE* is offline Monaro here i come
    VT Acclaim S2
    Aug 2005
    Huntingdale, Perth
    Default Quick question regarding air-con vents
    Good morning guys,
    Just had my air-con re-gassed yesterday. Also replaced a unit (not sure what it's called but it looked like it was mounted against the firewall).
    Now the air-con seems to be pumping really cool air just fine (like 12-13 degrees), however the air is only coming out of the dash vents. No air is coming out the vents in the centre console and the ones for the back seats. Any ideas on how to get these to pump the air.
    Apologies if this belongs in the air-con section but i don't think many of you pros go to that section that often.............
    Cheers.
    http://www.iplcricketnews.com/ - #1 site for all things IPL!
    VT Calais
    Sep 2007
    VX 'S' S1
    Apr 2005
    South East,Victoria
    are the vents open? . There is a little wheel type thingy in the middle of the vents which opens and closes them
    *VOLATILE*'s Avatar
    VT Acclaim S2
    Aug 2005
    Huntingdale, Perth
    Quote Originally Posted by Dayvo View Post
    That was the first thing checked dude
    *VOLATILE*'s Avatar
    VT Acclaim S2
    Aug 2005
    Huntingdale, Perth
    Quote Originally Posted by Chucknorris View Post
    maybe you have loose vacuum hoses behind the heater selector
    How do I get to them? Are you able to tell me how I can get to that? This would be nice to no as I am also planning to upgrade the dash (so I need to know how to remove the entire unit).
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Does it work in any of the other positions when you turn the dial? Do you hear a hiss when you select different vents?
    MY RIDE
    *VOLATILE*'s Avatar
    VT Acclaim S2
    Aug 2005
    Huntingdale, Perth
    Quote Originally Posted by accentstencil View Post
    Not even a peep from the centre console vent. Or the rear ones. The ones in the dash up near the front of the windscreen are pumpin'.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    How about your feet? Does it change to that when you turn the dial? If not, you probably have a leak or a hose off. There is a vacuum tank up under the dash as well on the passenger side.
    Visit my Facebook page
    *VOLATILE*'s Avatar
    VT Acclaim S2
    Aug 2005
    Huntingdale, Perth
    Not sure if I tried that option to tell you the truth. Will give it a go later.
    How do I get to the back of the vents?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You will have to pull the dash out.
    *VOLATILE*'s Avatar
    VT Acclaim S2
    Aug 2005
    Huntingdale, Perth
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Is there much to it? i.e. any specific points on the dash that make it pop out? Things such as clips etc.................
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Save me typing it out http://forums.justcommodores.com.au/...t-cluster.html The first bit tells you how to get the dash out.
    *VOLATILE*'s Avatar
    VT Acclaim S2
    Aug 2005
    Huntingdale, Perth
    Thanks dude, I will give it a crack on the weekend and let you know how it goes.
    *VOLATILE*'s Avatar
    VT Acclaim S2
    Aug 2005
    Huntingdale, Perth
    Hey dude, got the mechanics to do it for me (I had to get someone to supply/install new engine mounts; both left and right front ones) while they were doing a repair.
    Turns out "vacuum hoses" were not plugged in and blowing air back into the motor..............
  15. #15
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    There you go. Good to see it is fixed.
  1. Quick Question
    By vt_ss_5l in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2007, 12:13 PM
  2. quick question
    By pgen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2007, 02:52 PM
  3. quick sub question
    By Gunns VC in forum Car Audio
    Last Post: 23-09-2007, 07:26 PM
  4. Quick Question
    By ef_classic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-07-2006, 11:33 PM
  5. Quick Question: VT SS RIMS = Quick Answer please
    By Henerz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2006, 06:33 PM
