My 1997 VT has been leaking coolant and overheating. Yesterday after work i was on my way home and the engine temperature started rising drastically i was forced to pull over and let the car cool down. Started the car again and went for a drive watching the temp again it rose. Found something out, only overheats really quickly if the aircon is set to hot. As soon as it is set to cold from H it drops really quickly to about half way.
Also, I've noticed that my car has a really bad rattle under load. I dont know where it is coming from engine or tranny?? It doesn't do it when I shift into neutral and give it a little rev but it does do it when I move the steering wheel from left/right. The rattle doesn't happen all the time - but when it does, gets progressively worse as I continue to drive the car.
When I turn the car off and take a look at the engine - I can hear a hissing noise, like there is a build up of pressure and the hose just wants to explode. Not good huh?
All this has started happening since I flushed the radiator.
Any help would be great thnx
