Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: front sway bar
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Default front sway bar
    Bit of advice needed here guys. I need to replace the front sway bar linkage bushes . Just wondering if i should use the genuine factory rubber ,or go for the aftermarket jobbies like nolathane etc. Also is it best to replace the linkages as well as the bushes
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If the pins are fine and you only want to spend $20, just do the bushes. If you want to spend $35-$40, do the whole lot, pins included. Go aftermarket polyurethane like Nolathane, they stiffen it up and last a lot longer than rubber.
    Visit my Facebook page
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Ok, thanks for that . I'll go the Nolathane bushes and check the condition of the pins . Ta
    s_ikari2015's Avatar
    s_ikari2015 is offline Fun IS easier with an 8
    '02 Monaro V2 CV8 6m
    Nov 2007
    Australia
    I had Holden do mine once... they did such a terrible job about it one of the bushes was bulging out one side so much that the washers were almost touching.... I had another dealership fix the problem with Nolathane's.
    I haven't lost my mind, it's backed up on tape somewhere
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by s_ikari2015 View Post
    Thats why i do most repairs and services to my car myself.In the 34 years that i have been driving i'd say my cars have only been in the shop about 10 times , mostly for transmision services .
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    buy a nolathane kit it will last 5 times longer than genuine, kit comes with the pins, nuts and bushes, and is relitivley cheap
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    actually nolthane doesnt always last longer i went through a set in 1 yr and went back to rubbers and all is fine
    you dont need nolthane if ya not a racecar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Rubbish. Polyurethane is better in some applications than rubber. If the Nolathane bushes were installed correctly and greased, they would last longer than rubber.
    daron's Avatar
    VE SSV
    Mar 2006
    adelaide
    just saying not always
    pedders did mine and ddnt last long then when i went back to get another set i was told go back to rubber so i did and much better
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Well, Pedders can leave a lot to be desired in some branches. So can a lot of places.
    Umai Naa!!'s Avatar
    Umai Naa!! is offline R.I.P APY-88V :(
    VR S1 Exec. A4 3.8L
    Jun 2006
    Sthn H'Lands, NSW, Aust.
    Avoid Pedders period.
    Get some Nolathane Z links. Much stronger than stock, and alter the angle in which the link travels through, which causes less stress on the link itself.
    AUS12
    New project. New direction. New Ideas. No money!
    VT/VX Parts For Sale
    blake0182 is offline Blake
    VT executive
    Jan 2007
    perth
    i have the brand wasp Z link bushes and links the bushes are the polyurecthane ones , there all fitted up but i wasnt reali sure how the Z is positioned dose it reali matter or dose it find its own place
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    They will only go one way that looks right. Fit them so the threaded ends are as close as possible to vertical.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Don't the VT have different links to the VX ¿
  15. #15
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yep, VR-VT are the same, then the VX-VZ were the same.
  16. #16
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Ok ,thanks for the info . Might rebush the whole front end . When i hit the brakes at any speed over 80kays the front end shakes (again . thought i fixed that ) Would it be best to use nolathane bushes all round or would it make the ride a bit harsh ¿
  17. #17
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    That sort of problem would point to the brakes rather than the bushes.
    The only bushes I wouldn't use Nolathane on would be the inner control arm bushes. If you do, then you would feel every little bump on the road.
  18. #18
    Umai Naa!!'s Avatar
    VR S1 Exec. A4 3.8L
    Jun 2006
    Wrong... sorta.
    VZ uses a ball-joint at both ends.
    AUS12
  19. #19
    VX 'S' S1
    Apr 2005
    South East,Victoria
    I have put new rotors and pads on which helped a bit . Also checked the runout of the disc with a dial indicator and it was within specs .Also put nolathane tension rod dampers in which improved the handling 100 per cent but still got the shakes.
  20. #20
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Does the steering shake or the car? Can you feel the brake pedal pulsate?
  21. #21
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by Umai Naa!! View Post
    Wrong... sorta.
    My Super Pro catalogue lists VY and VZ as being the same as VX for the swaybar top mount, but the Nolathane one lists the VZ as being ball/ball. Must get an updated catalogue...
  22. #22
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Dayvo View Post
    Did you do the rear brakes as well because it could be them that are making the car shake.
    MY RIDE
  23. #23
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Quote Originally Posted by accentstencil View Post
    Or it could be an alignment issue too.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
  24. #24
    VX 'S' S1
    Apr 2005
    South East,Victoria
    the steering shakes which in turn shakes the car.the pedal doesn't pulsate . I have rolled down a hill in netural and slowly applied the brakes and they do not grab. Had wheel balance and alignment ,also rear brakes check out ok . any speed under about 70 kays it pulls up smooth with not a hint of a shake .
    Might have to drop it into a front end shop . ( not pedders lol) Amberley Autos has a pretty good rep around here .
  25. #25
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    There are a couple of things that can cause similar shakes, radius rod bushes, tie rod ends or rack ends, and even worn struts can make it shake. Does the steering wheel give a wobble when you hit a bump at 60km/h or over?
  1. V8 FE2 front sway bar part number and V6 springs
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2006, 01:58 PM
  2. V8 Front Sway Bar
    By VN Commy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-08-2006, 12:28 PM
  3. front sway bar link kit. VR
    By Hakka in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2006, 05:41 PM
  4. Rocky1 Fitting Front Sway Bar
    By Rocky1 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-12-2005, 07:47 PM
  5. front sway bars need replacing!!!
    By Fully in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 07:45 PM
