Results 1 to 8 of 8
Thread: vt berlina,97. grinding noise in rear end
    pebbles Guest
    Unhappy vt berlina,97. grinding noise in rear end
    we have recently purchased a 97, VT Berlina. It has a sort of grinding, whining noise in the rear when driven. Any ideas on what this may be?
    VW J&S Supa Sport Dune Buggy
    Sep 2004
    4 seasons in 1 day
    Apr 2004
    vx executive 3.8l s1, vs s ute 5.0l s3
    Dec 2004
    sydney
    rear brakes might be metal on metal check rear brake pads and replace them you might have to replace the rear disc aswell?????????
    RKZ234 Guest
    It could be a pad not releasing from the rotor and rubbing. If it is a grinding noise the pad may be down to metal and the noise you hear is the rotor being gouged by the pad (Not Good)
    Otherwise it may be, the diff, or an IRS boot may be damaged and a foregin body may have got in.
    Check all the wheel nuts are tight. (When I picked up a new Commodore work car not long ago, I got on the freeway within 3 km and noticed a very mild vibration and noise from the rear end. Did a U turn and had the car put on the hoist. As they went to take the rear wheels off, it was discovered that one wheel nut was missing!!! Not happy Jan!!
    If you have just bought it from a licenced dealer, take it back to get it fixed under warranty.
    Camotec Guest
    I would say either the CV joint in the rear end or as stated before the diff might need to be inspected.
    Ben
    pebbles Guest
    Thumbs up
    thanks everyone, i have it booked in for a thorough inspection today and will be getting it fixed under warranty if anything is needed. here's hoping that its nothing major.
    It is great to drive, only picked it up yesterday....
    thanks again...Deb
    RKZ234 Guest
    Quote Originally Posted by pebbles
    thanks again...Deb
    It's a little disappointing that it wasn't picked up by the seller in a pre delivery check & road test before you picked it up.
  1. Grinding Noise from engine...?
    By richie_cky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-11-2011, 12:06 PM
  2. grinding noise....:(
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2009, 12:15 AM
  3. VS V6 strange grinding noise.
    By Fitzy3VSVY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2006, 11:09 AM
  4. VT-II Berlina : Knocking noise from rear
    By dj_eddie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-02-2005, 02:22 PM
  5. Strange grinding noise
    By Bec in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-09-2004, 12:18 AM
