| VT - VX Holden Commodore (1997 - 2002) Talk about anything relating to the VT - VX Holden Commodore. |
20-02-2008, 04:51 PM
running out to oki
Ride: vt executive
engine light on
hi there doe's any one know which wire i can remove to stop the engine light being on as i am running my vt with the air flow meter removed as it run better with out it , if possible ,thanks
20-02-2008, 05:43 PM
Ride: MY08 Outlander XLS
If it runs better without it, then you have a problem with the MAF sensor.
__________________
It is better to be silent and thought a fool than to open your mouth and prove it.
Quote:
Originally Posted by DannyboyDS
Wholesaler of exhaust, suspension and brakes.
20-02-2008, 07:31 PM
running out to oki
Ride: vt executive
i know there is a problem with the air flow meter that is way it is not connected hence the reason why i need to disconnect the light from staying on
20-02-2008, 07:40 PM
Donating Member
Ride: WH II Caprice, 5.7
Quote:
You could remove the globe from the cluster. It would be a much better idea to fix the MAF sensor because when you do really have a problem you won't know if the engine warning light doesn't illuminate.
21-02-2008, 10:42 AM
Good idea....Rather than fix the problem, just remove the part.
I would get another MAF, pick one up from the wreckers.
__________________
21-02-2008, 09:24 PM
Ride: VY SII HBD Calais L67
Definately get another MAF. $30- $40 from the wreckers and give it a clean 1st. Cheaper than asking Holden to reset ur trouble codes
22-02-2008, 11:50 AM
You don't need 8 for fun
Ride: VT Commodore V6 S1
make sure to get one that has the same part number, however. I bought one from eBay and although it was "supposed" to be for my car it totally threw out the idling and everything. I bought it with a ported & polished housing. Ended up swapping my sensor back in. Instantly went back to smooth running. Ported & polished housing appears to have improved acceleration, along with the 70mm Throttle body and cooler thermostat.
__________________
I haven't lost my mind, it's backed up on tape somewhere
22-02-2008, 08:28 PM
running out to oki
Ride: vt executive
I have bought four so far, all starts off good than they die again thats why i want to remove it all together thanks
22-02-2008, 09:58 PM
Unless you get the car tuned for Mafless, I think it is crucial to your efficiency. If you have tried 4 MAFs' and no improvement, I think the MAFs' are actually good and the wire to the plug may be stuffed.
The Haynes manual has all the specific voltages for testing these things in it. Most Mechanics can measure the voltage of the MAF plug to tell you if it's working correctly.
23-02-2008, 12:03 AM
not for human consumption
Ride: VR EXEC
I reckon it's a great idea to pull the globes out. they all pi$$ me off. I say pull out the oil and battery lights too
note sarcasm
23-02-2008, 02:59 AM
Ride: VX SS 5.7L M6
TheForgotten , oil light too? the engin light cant really cause any damage so it dosent really matter if u take that out but if the oil comes on i would be checking oil level straight away!! its kinda vital.
__________________
13.3 1/4 exhaust only untuned!
23-02-2008, 06:51 AM
Donating Member
Quote:
I think he was joking.
23-02-2008, 09:08 AM
Take the brakes out too for weight saving
24-02-2008, 06:29 AM
running out to oki
Ride: vt executive
yeah good on ya lol
