Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VT - VX Holden Commodore (1997 - 2002)
VT - VX Holden Commodore (1997 - 2002) Talk about anything relating to the VT - VX Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 21-02-2008, 08:44 PM
nathans1987's Avatar
Ride: VX SS 5.7L M6
Trade Rating: (0)
nathans1987 Hitchhiker
Default reseting IAC ls1
how do you reset the IAC in an ls1?? my car idels at 1500rpm when it gets hot??
__________________
13.3 1/4 exhaust only untuned!
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 21-02-2008, 09:15 PM
Ride: VY SII HBD Calais L67
Trade Rating: (0)
chargedvx6 Executive
It is set to always self calibrate to factory presets. Usually IAC probs come from mods or faulty IAC valve or TPS afaik.
Have you done anything with the intake like descreen or porting?
  #3
Old 21-02-2008, 09:24 PM
Peanuts Inc.'s Avatar
Ride: 355 VG :)
Trade Rating: (0)
Peanuts Inc. MonaroPeanuts Inc. Monaro
it might be idling high from a split PCV hose.... its a common problem.... look at the t/b straight on and then look to left side of the t/b and there is a black hose that leads over to the rocker cover, it usually splits there and causes a vacuum leak and it idles high
  #4
Old 21-02-2008, 09:38 PM
Ride: VX SS 5.7L M6
Trade Rating: (0)
it only does it somtimes tho and only when hot usually?? i had a look at all of the vacume hoses n they seem fine
nope no porting or anything its all standard
__________________
  #5
Old 21-02-2008, 09:54 PM
Ride: 355 VG :)
Trade Rating: (0)
follow the hose i was talkin about right back around the back of the motor.... and it splits off into 2 lines... it splits there too
is it setting an engine light on the dash when it does idle high???
  #6
Old 21-02-2008, 10:00 PM
Ride: VX SS 5.7L M6
Trade Rating: (0)
nope never sets an engine light well i did get a tps once but that was only for a second its fine now and its got a brand new IAC coz i kinda killed the old one when i cleaned it hehe.
__________________
  #7
Old 21-02-2008, 11:59 PM
Ride: VX SS 5.7L M6
Trade Rating: (0)
changed the tps that seemed to help quite alot then i found a vacume leak from some sensor at the back of the motor now it idels at between 550 and 900 rpm moslt around 800 not sure if thats mormal i ran if for 20 min usually by then its starting to idel at about 1500+ so by theroy its fine now but i bet when i go on the road itll start doing wierd things again :S
__________________
  #8
Old 23-02-2008, 02:52 AM
Ride: VX SS 5.7L M6
Trade Rating: (0)
hmm still idels at 1000-1100............... its not the iac or the tps or a vacume leak??!!! there is no error codes :S
__________________
  #9
Old 23-02-2008, 08:55 AM
Trade Rating: (0)
Have you adjusted the idle screw on the throttle body? The little allen head screw. Try letting it out abit to close the throttle blade more but just remember how many turns you d o so you can put it back to the same spot if this doesn't solve it.
  #10
Old 23-02-2008, 10:36 AM
Ride: VX SS 5.7L M6
Trade Rating: (0)
it wont be that its too erratic like 1 second its about 350 ideling then i drive a bit and its up at 1100 then i drive a bit more and its at 900 :S
__________________
  #11
Old 23-02-2008, 11:21 AM
Trade Rating: (0)
Quote:
If that's the case, it's almost certainly a vacuum hose somewhere like Peanuts was saying. The erratic bit is the IAC trying to constantly compensate for the varying reading IMO.
  #12
Old 23-02-2008, 11:55 AM
Ride: VX SS 5.7L M6
Trade Rating: (0)
yeah thats what i thought but i cant hear feel a leak anywhere :P i have checked every hose i know off hmm i might just start changing stuff lol coz its obviously really small.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
reseting idle? jet_pilot VN - VP Holden Commodore (1988 - 1993) 6 21-12-2007 03:19 PM
Reseting the odometer speedotom The Pub 20 16-09-2007 09:27 PM
reseting springs (sydney) vt_on_20s General 0 06-05-2007 07:08 PM
Reseting Idle ROCKIN VR VR - VS Holden Commodore (1993 - 1997) 2 25-07-2005 03:40 PM
Bankruptcy | Adverse Credit Remortgage | Free Advertising | Home Loan | Mobile Themes Download | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
