Hi guys...
I just have a few questions for you guys in regard to my suspension setup in my VT Calais.
I am planning to put 20's under it and will have about 150kg worth of stereo in the boot. I want to drop it fairly low but hopefully still maintain a "decent" ride. I will also be bolting up a 4 point camber kit...front strut brace and am also thinking about getting the K-mac caster kits...not too sure on those either...??? Nolathane in all the right places and new rubber where Nolathane shouldn't go.
I need to make a decision of whether to get Koni Coil-over system or Koni Sports with my own choice of springs? What are your experiences with these? I am told that the Koni Sports are a very good spring and even on the softest setting...would still be better than any shocker. If choosing this setup, what kind of springs would you go with?
The Coil Over system I am told that I probably should go with if planning the setup that I mentioned, however the spring rates are very hard and will "rock my socks off".
If you guys could tell me your past experiences or give me the pros and cons of each so i can make a decision, would be great...any help is much appreaciated...thanks in advance...
Cheers, Joe
