Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VT - VX Holden Commodore (1997 - 2002)
VT - VX Holden Commodore (1997 - 2002) Talk about anything relating to the VT - VX Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 29-02-2008, 09:40 PM
chevdreamer's Avatar
Ride: VT Wagon
chevdreamer Executive
Question VT Temp Problem
My wife was driving the VT today when the temp skyrocketed and she got the hot message on the panel then it dropped quickly aswell. Later in the day i took it for a drive and it gradually climbed to about 3/4 on the gauge. After about 30 mins i went for another spin and within 3 minutes it shot straight up to hot then went to normal range within 5-10 seconds when i got home maybe 2 minutes later i felt the radiator etc and it was not hot at all so i carefully took the radiator cap off and it wasnt hot at all??? any ideas????
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 29-02-2008, 09:45 PM
eurekamad94's Avatar
PUNK LOVE FOREVER !!!!!!!
Ride: go kart
Trade Rating: (0)
eurekamad94 Executive
thermostat only bout 10-20$$$
__________________
[SIGPIC][/SIGPIC]
  #3
Old 29-02-2008, 10:02 PM
don0xer's Avatar
Ride: 2000 VX Calais 3.8L Supercharged
Trade Rating: (0)
don0xer Executive
bleed ur system, probably air in the system, if that dosent help, take it for a 5 min drive to get it to operating temp, then turn on the heater, which should open the thermostat manually. If driving with the heating on and thermostat open fixxes it replace ur thermostat.
  #4
Old 29-02-2008, 10:04 PM
accentstencil's Avatar
Donating Member
Ride: WH II Caprice, 5.7
accentstencil Caprice
Perhaps a faulty coolant temperature sensor.
__________________
  #5
Old 29-02-2008, 11:04 PM
Ride: VY SII HBD Calais L67
Trade Rating: (0)
chargedvx6 Executive
If the radiator is cool after it over heats chances are that the thermostst isn't opening. Very easy to change.
  #6
Old 29-02-2008, 11:22 PM
Ride: VT Wagon
cheers will replace thermostat and flush cooling system as it is due anyways.
  #7
Old 01-03-2008, 09:23 PM
SlickHolden's Avatar
Morgage. **** Wrong Again
Ride: 2000 VT II Berlina V6
SlickHolden Berlina
Does the fan kick in??.. Someone nicked my fan relay and the temp went way over half we ****.
__________________
  #8
Old 01-03-2008, 10:45 PM
DND DND is offline
Banned
Ride: N/A
DND Executive
my was the waterpump as soon as the system losses presser it jumps straight to HOT
  #9
Old 02-03-2008, 07:48 AM
Rovert's Avatar
Ride: 2007 VZ ACCLAIM WAGON
Trade Rating: (0)
Rovert Executive
splurge out & change hoses & heater taps as well...
__________________
  #10
Old 02-03-2008, 09:42 AM
Ride: vt ss 5.0ltr
timay86 Executive
hey ppls , my vtss ser 1 is doing the same thing how do you tell if its the thermostat or the water pump as one person mentioned cheers tim
  #11
Old 02-03-2008, 10:55 AM
DND DND is offline
Banned
Ride: N/A
DND Executive
when it gets hot check the waterpump for any leaks you should see it running down the front of your motor
It can be as easy as just your radiator Cap is stuff and losing presser
So check that to
  #12
Old 03-03-2008, 10:31 PM
s_ikari2015's Avatar
You don't need 8 for fun
Ride: VT Commodore V6 S1
Trade Rating: (0)
s_ikari2015 Executive
you can test a thermostat by putting it into a pot of water and bringing it to the boil with a thermometer in it. When the temperature gets to around 93 degrees (or whatever temp thermostat it is) the thermostat should open. If it doesn't then replace the thermostat, or just leave it out of the car completely.
__________________
I haven't lost my mind, it's backed up on tape somewhere
  #13
Old 07-03-2008, 07:46 PM
dazza33's Avatar
Ride: 98 VT Wagon
Trade Rating: (0)
dazza33 Executive
My VT did exactly the same, ever morning for a week or so. Took it to Natrad, they flushed it, replaced the thermostat and never happened again!
  #14
Old 08-03-2008, 01:11 PM
Ride: VZ Wagon 2005
phantomwalker Executive
Default Coolant Tempurature Sensor - Where?
Have over heating -possible cracked head.
But first I needed to change radiator (big hole), removed termostat, flushed system.
Have noticed fans not cutting in. Tested both fans from relay positions and they work fine. But do not appear to be getting a ON relay to turn fans on.
Is there a temperature sensor I can check and if yes where is it located (VT 89 V6 EFI)?
After this I think its bad luck for my sister, head could be blown.
Any help appreciated,
Phantomwalker
  #15
Old 08-03-2008, 01:36 PM
