Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VT - VX Holden Commodore (1997 - 2002)
VT - VX Holden Commodore (1997 - 2002) Talk about anything relating to the VT - VX Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 02-03-2008, 08:52 PM
Ride: xv supercharged
Leanne Executive
Exclamation vx base idle set/reset?
hi.. has anyone got the base idle check/reset for vx supercharged com.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 03-03-2008, 01:23 AM
Ride: 'Enhanced' Y Series Senator Sig
Trade Rating: (1)
minux Off the chartsminux Off the chartsminux Off the chartsminux Off the chartsminux Off the chartsminux Off the charts
Posted in wrong forum. moved.
__________________
minuxx dot net
Buy my Prints below
  #3
Old 04-03-2008, 09:08 PM
Ride: vt berlina
Trade Rating: (0)
convas Executive
Quote:
According to the service manual you need a scan tool to set the IAC to 0 steps then you set the base idle.
I dont have a scan too so I guessed at getting it to 0 using procedure below.
1 Turn the throttle stop screw until 1000rpm in Park on Neutral
2 Disconnected the IAC.
3 Turn the throttle stop screw until 450-550 RPM in Park or Neutral
4 Shutdown engine and reconnect IAC
5 Start Engine and run for 5 seconds
6 Turn off Engine for 10 seconds
7 Restart engine and check for proper idle.
  #4
Old 05-03-2008, 10:53 PM
sp001in's Avatar
vyma100
Ride: VY V6 UTE - MALOO KIT
Trade Rating: (0)
sp001in Executive
where did you get this info from?
__________________
HSV - I have a fake one, but it looks better than yours
  #5
Old 06-03-2008, 06:08 AM
Doctor Bob's Avatar
Grandpa
Ride: VT V6 Exec & VN V6 Exec
Trade Rating: (0)
Doctor Bob MalooDoctor Bob Maloo
the IACV reset itself at every ignition cycle, best dont mess with it if theres no issues
  #6
Old 06-03-2008, 07:11 PM
Ride: vt berlina
Trade Rating: (0)
convas Executive
Quote:
All but step 1 is from the service manual.
Section 6C1-3 Service Operations
3.11 Fuel Control System
Throttle Stop Screw - Check or Reset
Quote:
That is true but the question was how to set the base idle not how to reset the IAC, the base idle is contolled by the throttle stop screw not the IAC.
  #7
Old 06-03-2008, 07:28 PM
Ride: VY SII HBD Calais L67
Trade Rating: (0)
chargedvx6 Executive
Base idle would be virtual at best wouldn't it? The IAC is the tool of the ECU to keep the revs at the preset value in the tune. The idle screw is irrelevant really because to a point the IAC will over ride that setting anyway
  #8
Old 06-03-2008, 07:51 PM
Ride: vt berlina
Trade Rating: (0)
convas Executive
Yes that is true, the base idle is the minimum idle speed you would see if the IAC is fully closed (0 steps) the ECU expects the base idle to be set to 450-550rpm and knows roughly how many steps it needs to maintain the desired idle speed, if the base idle is wrong, ie too low then you may get a bit of stumble when going off throttle until the ECU adjusts the IAC count, depends how far out it is.
If the base idle is too high then the IAC wont be able to bring it down to the desired speed, ie if the IAC goes down to 0 counts and the idle speed is still to high.
  #9
Old 07-03-2008, 09:19 PM
Doctor Bob's Avatar
Grandpa
Trade Rating: (0)
as i said dont mess with it if theres no issues
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
V6 Base Idle Reset convas VT - VX Holden Commodore (1997 - 2002) 3 09-04-2008 07:15 AM
VE wheel base SSbeast VE Holden Commodore (2006 - ?) 3 05-01-2007 04:15 AM
base idle daniel VR VR - VS Holden Commodore (1993 - 1997) 17 07-08-2006 01:28 PM
Wheel Base Length sexypete VB - VK Holden Commodore (1978 - 1985) 1 03-03-2006 01:16 PM
Online Loans | Debt Consolidation | Debt Consolidation | Bad Credit Mortgages | Cingular Ringtones | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
