| VT - VX Holden Commodore (1997 - 2002) Talk about anything relating to the VT - VX Holden Commodore. |
03-03-2008, 07:47 PM
Ride: VY Berlina V8 & VZ Adventra LX8
How to remove wheel stud?
Hi - the brake place must have cross threaded the nuts or something. While undoing the nuts to check the inside of the tyre, the nut sheared off!
How do I get the stud out and replace it please guys.
Thanks
03-03-2008, 07:48 PM
So Wet For You!
Ride: VP Calais International, VP Berlina LX Wagon
Get a mobile mechanic to come around and do it, and send the bill to the tyre place.
__________________
2001 HSV VX Senator Signature - 1 of 23 Manuals
-402 Stroked LS2-
-V7 Blower-
-Polished Intercooler-
-MSD Ignition-
-DiFillipo Exhaust-
-Tan Coulsons-
-Genuine VE GTS 20s-
-Fully Adjustable Suspension-
-Rip Shift-
Quote:
Originally Posted by commsirac
try and sound like I know what im talking about
Sums up all of your posts!
Quote:
Originally Posted by paraphrased from Philthy
Stabbing someone, the same as having a loud exhaust!
03-03-2008, 07:52 PM
Good idea, but I have moved intersate in the last couple of weeks...
03-03-2008, 08:00 PM
Donating Member
Ride: WH II Caprice, 5.7
They are pressed in. I have bashed them out with a hammer but I don't know if that is correct procedure or not. Just be careful not to warp anything. I would remove the hub assembly to do it.
03-03-2008, 08:01 PM
Tells it like it is.
Ride: VE SS-V, VP SS
Just knock it out and put a new one in. They are only pressed in.
Reaper
03-03-2008, 08:12 PM
Knock out from behind? or use something more sophisticated?
Thanks
03-03-2008, 08:15 PM
Donating Member
Quote:
Thanks
From the front. The threaded end.
03-03-2008, 08:34 PM
So Wet For You!
As said, from the front.
I've only changed studs on live axle, not sure if you'll need to pull the disc off or not to remove them.
This is the exact reason why i do my own wheel nuts up. If the tyre shop doesn't allow this, they don't get my business.
__________________
-402 Stroked LS2-
-V7 Blower-
-MSD Ignition-
-DiFillipo Exhaust-
-Tan Coulsons-
-Rip Shift-
03-03-2008, 08:45 PM
Ride: MY08 Outlander XLS
Yep, bash it out with a hammer once the rotor is removed. To put the new one in, put it through the hole from behind and then put a large washer over the stud. Put the wheel nut on backwards and do it up until the stud is seated. You may have to use two washers if the nut bottoms out on the thread.
__________________
It is better to be silent and thought a fool than to open your mouth and prove it.
Quote:
Originally Posted by DannyboyDS
Wholesaler of exhaust, suspension and brakes.
03-03-2008, 08:48 PM
Drop A Patch....
Ride: VS Clubsport, GK Sigma Turbo, GJ Sigma V6 Project
I tried to get 2 of mine out today as they are a bit rooted.
But when i knocked em out... they couldnt get all the way out, there was a plate stopping them, needed about another 10-15 mm to get em out,
Any suggestions?
03-03-2008, 08:51 PM
So Wet For You!
Have you got the rotor off as Not_An_Abba_Fan said?
__________________
-402 Stroked LS2-
-V7 Blower-
-MSD Ignition-
-DiFillipo Exhaust-
-Tan Coulsons-
-Rip Shift-
Front or rear?
Reaper
03-03-2008, 08:52 PM
Donating Member
Any suggestions?
I think if you rotate them there is like a cut out section that allows you to get them out.
