Results 1 to 23 of 23
Thread: About to remove this....??
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    Default About to remove this....??
    hi, the hubs on my vt are rusty and look crapola, iv bought some rust remover, primer etc but im not sure how to remove the hub?
    this is going to be a no brainer for someone but im still learning so any help would be good. Im starting on the left rear and this is what im looking at;
    it looks like im going to have to remove the caliper? do i have to crack the bearing to get the hub off? also how easy is it to reposition the caliper after i remove it? any help will be great, thanks
    no longer a hoon by association - the commodore is gone
    wagon
    Nov 2006
    South East Vic
    Quote Originally Posted by nicko View Post
    you need to remove the caliper, and the end cap with the bearing. then the disc comes off
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You only need to remove the calipers.
    MY RIDE
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    getting the bearing off is that just done with a hammer and screwdriver or will that stuff it? will i need to replace anypart of the bearing once i remove it?
    thanks mate
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    Quote Originally Posted by accentstencil View Post
    so what is holding the hub on? is it those 2 flathead screws at the top and bottom of the hub?
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    i cannot for the life of me crack the 2 bolts holding the capliers on!!!!! is it just the two 19mm bolts of the back of the caliper, any ideas how to get them undone?
    wagon
    Nov 2006
    South East Vic
    breaker bar and a 5 point heavy duty socket
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    cheers mate, the caliper is off
    how does the disc/hub come off? looks like i need to remove the bearing cap? any idea how this comes off?
    wagon
    Nov 2006
    South East Vic
    well the other bloke said that you dont need to take them off but from what i remember you did grab a screw driver and a hammer and go anticlockwise to undo it
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Make sure your handbrake is off .If that doesn't work you might have to back off the brake shoes
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    Quote Originally Posted by Dayvo View Post
    OMFG, i cant believe i left the handbrake on!!! i feel like a d!ck but im glad im learning from my mistakes. thanks Dayvo rep left, big help mate cheers
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I'm confused, do you want to paint the rotors or the hub assembly?
    MY RIDE
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    the rotor/hub not the actual rotor blade but the surrounds
    i just finished the primer and painted it then;
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Whilst i can't help with how to get the rotor off, its great to see your setting an example and using Axle Stands.
    Too many times i see people doing work on their car with just a jack under there (sometimes even just a scissor jack)
    Top effort!
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
  15. #15
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Ok, good, then all that was need was to remove the calipers as you now know.
    MY RIDE
  16. #16
    wagon
    Nov 2006
    South East Vic
    Quote Originally Posted by STEALTHY View Post
    Top effort!
    looks good mate nice small effect
    and stealthy i had a scissor jack collapse while i was under the car just before i got the axle stand in the right place and the rear end of a vn come down on me
    not cool!!
    swer by trolley jacks now i threw all scissor jacks out that we had
  17. #17
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by ROCK3N View Post
    not cool!!
    I havn't had one collapse, but scissor jacks don't lift my car high enough to get the wheels off. The first thing i do when i buy a car, is throw the scissor jack in the bin, and throw in my trolley jack.
    cheers sexy
  18. #18
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    i used a scissor jack today and got the wheel about 5mm off the ground and then it threaded the shaft and wouldnt go up or down. so i got the trolley jack out and then did some arm stretches and threw the scissor jack down the road. i made those jack stands last year at uni and got them approved by australian safety standards, they are stamped and in the register
  19. #19
    STEALTHY™'s Avatar
    Jan 2005
    Doesn't mean there any good
    cheers sexy
  20. #20
    wagon
    Nov 2006
    South East Vic
  21. #21
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Hey Nicko, don't forget to use a little 'loctite' on those caliper mounting bolts when you re-fit them!!...don't want them working loose.
    Pablo
  22. #22
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    yeh but considering they have been made to comply with the same standards as the one you use under your car im sure they will be fine
  23. #23
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    Quote Originally Posted by pablo View Post
    Pablo
    thanks mate, will do
  1. How to remove cam
    By ascension24 in forum V6 Development And Modification
    Last Post: 13-03-2007, 11:46 AM
  2. how to remove
    By figjamidhVK8t4 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-10-2006, 07:17 PM
  3. should i remove IRS
    By fraesralj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2006, 06:29 AM
  4. How do I remove a decal???
    By misslisa in forum General Discussion
    Last Post: 17-03-2006, 09:37 PM
  5. How to remove?
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-10-2005, 12:24 PM
