Ay guys I purchased some fit rockers, though im not sure if they are 1.9:1 or 1.97's?
How can I tell ?
Thanks
That picture would be of no help as it doesnt indicate which ratio they are, and you could only tell off the position on the pushrod cup. But it would be so slight. Ask the person you bought them off.
The amount of flex they will get sort of negates the ratio IMHO. Maybe get a stock rocker and measure it's distance from the trunnion then do the maths. Maths was never my strong point so DIY the formula.
On the rocker it doesnt indicate which ratio they are anyway?
how much did you pay for them? look on the fit site and match them up... the 1.97's are more expensive
Got them 2nd hand, I know there more expensive. Tryd to match them up, but from pictures they look the same... hard to tell with re-machined rockers
wont matter much in performance, i think its only a few kw(2-3) diffrence between them anyway. but im sure its nice to know if youve got the best product out![]()
Not the performance side im worried about, its the pushrods ect.
Clutch slipping problems - i replaced slave & master cylinders - still not engaging - going further in to throw out bearing & return springs. I disconnected gear stick linkages, to find leakage on around trunnion rod. Is this a leaking seal? If so would this cause me to slip & miss not enage in any gears? do i proceed further into gearbox? Please help thankyou.
