Hi,
i'm looking at getting a CRS supercharger kit and the hi-boost pulley (all for under 2500, which is why i'm getting it) now, do i need higher flow injectors or a fuel pressure regulator or what? i'v been reading around and can't find any straight answers...
also, CRS recomend getting a new memcal from castle auto electrics cos they have them made up specially for that purpose, and are about $500 exchange. should i go for that or try and get a cheap aftermarket ECU like a Microtech etc.? the reason i'm asking is the memcal option seems like it will be generalised to fit any VT V6, while if i get a computer, the dyno guy will be able to tailor it to my car.
any help appreciated!
PM 'daron' he should be able to answer your questions
no longer a hoon by association - the commodore is gone
Whilst this is not for the supercharger you mentioned, there is a FAQ on the v6supercharged site.
Forced Induction Technologies - Australia's V6 Supercharged Specialists
question 22
lists all the things you need to do to a l36 to make it like teh l67.
argh, dont get a microwreck man, you've already got a perfectly good ecu. just have a kalmaker tune done for it and flashed onto the memcal.
as for the fuel side of things, you really only need to upgrade the injectors, the fuel pump and everything will be fine for the boost you plan on running.
Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
firstly, cheers Daron for the info!
sircruisealotVS, where can i get this tune done? and how much will it cost approx?
another thing, will it be safe to drive my car to get tuned? or should i just use the standard fan belt and bring the other one in when i get it tuned?
cheers guys
i dunno mate, i live in qld...but i know there's plenty of places in vic that can do it. depending where you go it'll cost around $1k give or take.
hello again,
does anyone know where to get some supercharged 6 injectors?
and do i have to get the factory 36lb ones or are there after market ones that would work too?
cheers guys
motor traders holdens heaps laces do the 36 lb ones i went 42lb
ya can get new or referbished and reflowed for under 100 bux a pop
does anyone know what size intercooler can i fit to my Vt?
also, has anyone had any experience intercooling one of these CRS kits?
and what about moving the throttle body before the charger?
thanks guys
coolness. how do i move the throttle body? is there a thread about it?
geese if i typed one up it would take me for ever
i actually got a second throtle/body and bored it out and blocked up holes and placed back to back at from and then bolted together
the throtle cable is long enough to go to the front and bend back around
youll need a flange type pipe to go where t/b is now
all up i used 3 t/bs
