ive got myself a 2002 vx motor im going to drop into a 4runner , is there anything on the motor i should change while it is out of the car,
i am going to do the rear main seal as i heard they leak a bit
also the welch / welsh plugs ,
is there anything else i should be look at doing,
also can you run the supercharged heads on a standard ecotec engine, not so much for preformance, just wondering if its possible or would other things have to be changed
thanks
The supercharged heads are identical to the N/A heads except fro the pre existing injector ports. So yes they can be used.
Replace:
Gaskets (head, water pump, rocker covers, sump etc)
Spark Plugs and leads
Oil/air/fuel filters
Check the water pump too, they are prone to failing
high pressure clean the engine bay
i hate a dirty engine bay
