Results 1 to 13 of 13
Thread: Removing rear VX springs
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Default Removing rear VX springs
    Tried chucking some lowered springs in the back of the VX, but can't get the old ones out....how is it done?
    First tried with spring compressors but couldn't compress them enuf to go over the bump things in the middle of the spring seats, then tried droppin the shocky, but that didn't drop the diff assembly much at all, which yeah ment it didn't work.
    Is there an easy way to get them out or do I gotta buy a special tool or sumfin?
    adam69 is offline Banned
    VT Clubby
    Oct 2004
    Jack up one side,put a stand under the car.Remove wheel,undo nut on the bottom of the shocker(19mm)from memory.With a slight levering of the lower trailing are the spring will come out.Put what you took off back on and do the other side.Piece of ****.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    With the stabilizer bar, it is easier to have the whole rear end off the ground. Less tension on the control arm when levering it down. Sometimes you may have to compress the spring to get it out. Undoing the stabilizer links helps too.
    Visit my Facebook page
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    The way I did mine was to take the drive shaft off as well as the shock and the stabilizer bar. Just be careful you don't strech the brake lines in the process. I unclipped mine from the body to allow for some more travel.
    I am sure it is the same for sedan and wagon
    BTW the driveshaft bolts are a pain to undo. Used the jack handle as an extended leaver
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    vy ss 235rwkw / HZ tonner
    Dec 2007
    Northern suburbs, Melb
    i just got a mate to jump on brake rotor after dropping shocker bolt. then lever the cvnt out.
    DANNY8's Avatar
    Apr 2004
    Ok well it seems I'm just not trying hard enuf. We put pressure on the brake hub to try and push it down, but we were worried bout breaking the cv joint or sumfn haha. So pretty much just compress the spring as best as I can, then undo the shocky bolt and force the brake rotor/cv joint down until I get the spring out? Apart from the brake line, can I do any damage from doing this?
    I don't wanna remove to much, just incase I stuff sumfin up. If I can't get it by undoing the shocky and forcing the rotor down, I might just pay someone to do it....I'm just really worried bout breaking something expensive haha.
    Thx heaps for ur help guys!
    VT Clubby
    Oct 2004
    Ive done it the way ive decribed many times without a problem.I use the jack handle to help lever the trailing arm down.
    DANNY8's Avatar
    Apr 2004
    So the pressure which is against u when u push down is just the sway bar or sumfin? It isn't nuthin which will break in a hurry?
    VT Clubby
    Oct 2004
    I dont think anything will break.If you want to undo the sway bar and see iif that helps then go for it.Its not too hard.
    vp exe s2 3.8
    Dec 2004
    When my son done his vx the first time we forgot to release the handbrake xxx. Second time found the spring compressor too long, and had to cut the thread down too 150mm. Once that was done the springs came out, with the help from jimmy bar (thanx jim). You also need to remove the shocks (top or bottom it's up to you), the lowered king springs just fell in. Hope this helps.
    "Ah ha! Got the drop on you with my disintegrating pistol. And brother, when it disintegrates, it disintegrates.
    Heh, well, whatta ya know, it disintegrated."
    vt 2000mdl exec vl berlina
    Apr 2008
    u just un do shoker un do rear sway bar jack it up from body the diff falls down u should then be able to use pressure from ure hand to slide them out
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Quote Originally Posted by DANNY8 View Post
    Someone already mentioned it but handbrake OFF! lol
    You will never get a spring out with the handbrake on.... no unless its like a SSSL.
    If you have fe2 springs undoing the shock and having a mate press down on the control arm while you jog the spring out should be enough...
    With non fe2 springs you will need a spring compressors for sure... How do you mean you couldn't compress them enough?? Should be EASILY able to compress the spring enough to lift it out nice and easy.
    Good luck with it!
    vt_on_20s is offline vt gone ve s2 ss ute now!
    ve ss s2 ute
    Mar 2007
    sydney
    dodgy but easy way... wont break anything, just jack the car up, take the wheel off and put a bottle jack in there so it pushes the lower arm down and the spring will be easy enough to pull out and even easier to get the new ones in...
  1. help removing springs (wagon)
    By vswgn_55 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2008, 09:08 PM
  2. removing springs
    By kozij in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-12-2007, 06:15 PM
  3. Removing those rubber plates from rear springs
    By buzurk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-02-2007, 05:07 PM
  4. Wtb Vs Non Irs Rear Springs
    By biganf in forum Swap / Wanted to Buy / Trade
    Last Post: 10-01-2007, 06:04 AM
  5. rear springs for VS IRS
    By demenace in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2006, 03:16 PM
