Results 1 to 7 of 7
Thread: plug in fuse compartment
    blake0182 is offline Blake
    VT executive
    Jan 2007
    perth
    Default plug in fuse compartment
    dose anyone no what the plug/socket that has i think 3 or 4 wires coming off it and is in fuse box under the drivers steering wheel it is kinda hideen but if u put your hand up in there u can pull it down it has about 5cm maybe more of length on it i reali need to no as i have cooked the active lead and dont no where it leads
    VX Executive S2
    May 2006
    Frankston South Vic
    sounds like the diagnostic plug connector
    Where Holden plug their tech2 into
    vs exec series 1 and vt series 2 acclaim
    Jan 2006
    i think it may be the wiring for foglamps if you don't have any connected then that would be my guess
    vn v8 5 speed commodore executive
    Sep 2005
    moree
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    There are a couple of unused plugs up there in some cases. I know one is for fog lamps, that is you don't already have fog lamps. I had 2 plugs up behind the headlight switch, which is roughly in the same area. I don't know what the second one was for.
    MY RIDE
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    VT executive
    Jan 2007
    perth
    what is t82 ? , why are people saying for the tech 2 dosnt the tech 2 plug into the connector at the bottom of steering column ?
  1. VZ Dash Compartment
    By Premier 350 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-12-2007, 01:02 PM
  2. plug under fuse box???
    By richardvy6699 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-09-2007, 06:15 PM
  3. storage compartment?
    By gottavecalaisv in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-02-2007, 02:40 PM
  4. Replies: 11
    Last Post: 26-12-2005, 10:48 PM
  5. Glove Compartment
    By Melfice01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2004, 03:44 PM
