Results 1 to 4 of 4
Thread: another aircon question
    vs exec series 1 and vt series 2 acclaim
    Jan 2006
    Default another aircon question
    Hi all,
    i've lookes all through the stickies but can't find an answer to this problem i have a series 2 vt acclaim when a/c is on there is no difference between recirc air and normal air i've checked for vacuum leeks and it even hisses when i turn the direction selector all though not all directions work for some reason any help THANX
    hispeedvp's Avatar
    hispeedvp is offline VP SS Ute
    VP Group A Ute
    Jul 2005
    W.A
    i this just when air con is on, or all the time, could be something physically blocking the flap that directs air induction from inside or out, if its only when air con is on i would say the switch maybe, does the aclaim have climate control? or is it all rotary switched?
    [SIGPIC][/SIGPIC]My New Engine, A Work In Progress
    Jan 2006
    when i switch fan speed on then push ac on or off there is no difference in air flow it doesn't have climate control. i was thinking it was the switches as well however wanted check with people in the know first before rippin the dash apart
    Jan 2006
    sorted this out turns out the little rubber grommit thing that redirects the vaccum so you can change between demist face and recirc was stuffed replaced the whole unit with a second hand one from ebay for 10 bux now works a treat
  1. wiring a neon to the aircon switch to show that the aircon is on
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 25-03-2007, 08:44 AM
  2. aircon controls question [84 vk berlina]
    By unregistered in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-01-2006, 11:05 PM
  3. aircon question
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2005, 01:07 PM
  4. Disconnecting the aircon question VR
    By Flange in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2005, 10:38 PM
