By the look of it a new seal is about the only thing that will fix it.
MY RIDE
The rear window will need to be removed and as Accentstencil suggest you will require a new rear window seal.
I like my roo well done
Bleh, thought so...just got it tinted too. Though that shouldnt matter. How much I wonder?
apparetnly this is a common problem mines got a buckle in the exact same place lol cept mines not that bad but it looks ugly
my back rubber moved a little back in 1998, just 4 months after buying it. Holden said they would have to replace the rear window. We just had it tinted, and Holden said they wouldn't cover that (grrrrrr!)
Any way it was only minor and they said it had no effect on the window leaking water as it is just a dress trim.
Well this year after a real hot day it buckled like sprocket's!!!
And yep, the only way to fix it is to remove the window and replace the rubber, which Holden actually changed mid way through the series 1's life (Which is strange because sprocket's 2000 VT should be a series 2???? They also changed the front window rubbers/plastics because they can buckle too).
