Results 1 to 11 of 11
Thread: Performance Coilpacks and Ignition Leads worth it??
    VX
    Mar 2007
    South Australia
    Default Performance Coilpacks and Ignition Leads worth it??
    As title states is replacing stock coilpacks and ignition leads with upgraded ones worth it or just a waste of money?
    some brands and products would be good to
    thanks
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    I try an avoid replaceing OEM with OEM when i can get a better aftermarket product.
    MSD are my spark vendors of choice.
    aZk.
    VX
    Mar 2007
    South Australia
    yeah ill have to sus them out, just looking at upgrading some of the parts under the hood so thought might be a good place to start
    VT Berlina & mazda 2 DE
    Jul 2006
    I dont know that it is worth it much- but i would be keen to hear the results. I imagine it would only be worth it for forced induction, or maybe in N/A if you played with spark gaps-found the new optimal gap for the increased spark
    VX
    Mar 2007
    South Australia
    yeah im looking at going down the forced induction path end of the year so
    azkwazere: wheres the best place to get MSD ignition stuff from just usual sprints, autobarn etc??
    May 2005
    .....SE Burbs
    commsirac is offline Banned
    vx
    Aug 2007
    Quote Originally Posted by wobbly View Post
    thanks
    Id of thought GM has already done their homework on this and if they could get more power or economy out of the engine by adding something as simple as more spark then they would have done it.......given the publication of fuel consumption figures and the quest to beat the frauds. They already have three coil packs for six cylinders.
    Certainly new leads by themselves wont change performance, better quality leads just offer superior insulation or ability to stop higher voltages leaking out before they get to the spark plug.
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    MSD coils for V6 are good but only slightly better than stock so save your money if current coils are ok.
    Better still are Holden supercharged V6 coils, but again if your current coils aren't misfiring save your money for now.
    Leads on the other hand, the stock ones are great for your stereo and thats about it, for performance they start deterioating from the moment you run current through them.
    MSD and Magnecor both make excellent silicone spiral wound wire core leads.
    The spiral wound wire has the wire spun around a central core (usually fibreglass) and the wire is continuous from end to end.
    This continuous wire strand gives good current flow and the spiral winding stops any interference through your stereo.
    These types of leads can last almost indefinately if looked after and the outer sheath (usually silicone) doesn't get broken.
    The stock leads are carbon impregnated fibreglass and over time the carbon breaks and gets gaps along the length of the lead leading to misfiring etc.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Ebay has some MSD coil packs now.
    One good thing about getting some expensive spark plug leads is they do give some better performance hard to notice, But they last longer, And they should they can cost a mint.
    Stuck some 10" Top gun made to order leads on my old VP, Over 12 months still purring along nice with iridium plugs.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    VX
    Mar 2007
    South Australia
    alright some good info there, think i might just change leads for now and put money towards something more worthwhile perhaps haha
    cheers for all the help
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Just might add that my Magnecor 10R leads are over 10 years old and don't miss a beat.
    So they have definately saved me money in the long run.
    Had them on my VL turbo then had one extra lead made so that I could fit them on my superchared 6.
  1. Ignition Leads
    By AWETZM in forum General
    Last Post: 05-09-2007, 01:16 PM
  2. dam ignition leads
    By sKaLpa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-03-2007, 09:12 PM
  3. Ignition leads
    By Aryashahin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-12-2006, 10:27 PM
  4. Ignition Leads?
    By Torniquet in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-11-2006, 10:33 AM
  5. Performance Plugs & Leads
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-06-2006, 09:28 PM
