Results 1 to 8 of 8
Thread: VT Ignition.. Stuck in ACC postion
    VT Executive Sedan S1 Manual
    Nov 2006
    Unhappy VT Ignition.. Stuck in ACC postion
    I have a question that i hope some can answer for me..
    What a night for this to happen, Good Friday Eve.
    I have a VT - 2000 - Manual
    My ignition barrel felt a little difficult to turn over the last few days.
    i.e. when key inserted, into barrel.
    I would have to wiggle the key back and forth to start.
    The internal rotating part of the barrel would seem to be sitting in a little.
    I will pull the key back and reinsert and the key would turn with ease.
    Today, I went to start my car, key felt sticky. so i wiggled it and the key turned.
    "Now i,m not quite sure if i felt a something give way"
    The key turned and the dash lights and radio started, in "ACC position" key kept turning to start..
    But nothing happened, I can lock my steering wheel.
    But when I turn the key to start or off power is still there in ACC position STAYS THE SAME. ON
    I,m thinking the barrel has collapsed and the ignition switch doesn't sense the key movement..
    BUT owning a VT, I have found not always what you think.
    Have removed the Positive Terminal from the battery, so not to run flat.
    Thanks guys...
    I have a Holden workshop manual, so removal and refit seems straight forward if the barrel is gone..
    Would anyone know approximately how much they would cost?
    As cash flow is low ant Easter break on... Cherrs
    I also tried my spare key and another spare head.
    Unlock button would not unlock doors... That,s got me stumped.... unless doest respond in ACC position.
    Happy Easter to all as well.
    Great site.
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    Nov 2006
    VY SII HBD Calais L67
    Dec 2006
    Omega security in Barkly street, Footscray have a travelling service and they did my Mums' car for $160. New barrel and keys including the travel.
    Nov 2006
    Nov 2006
    I wonder if anyone can answer 2 small questions.
    1/
    Do I need to purchase a full barrel and key assembly with switch or barrel separate.
    So I can use the key head matched to the switch. Two screws to change head.
    To avoid reprogramming, as its easter and may only be able to purchase from dealer. Most businesses closed.
    Was wondering, if the mechanical side it what normally breaks !!!!!
    2/
    If programming is required, can be done off car. i.e. whilst at dealer with new barrel/key set or auto elec? As car is stranded.
    thunder
    Jun 2005
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The new barrel comes with a set of numbered brass tumblers, when you install it, you put them in in the same order as your old barrel. All you need to do is purchase a barrel assembly, around $50.
    Visit my Facebook page
  1. How to remove a stuck ignition barrel VN-VS
    By undar8ed1 in forum Holden Commodore How-To's
    Last Post: 13-02-2012, 04:33 PM
  2. ignition its stuck
    By sexcvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2006, 09:34 AM
  3. Help! Key stuck in ignition!!
    By AZBALL in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2006, 08:12 AM
  4. vs statesman ignition stuck on..barrel or BCM ?
    By matt2950 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-09-2005, 08:55 PM
  5. help! car stuck, worn ignition barrel cant turm
    By rgormley in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-04-2005, 12:03 PM
