Results 1 to 4 of 4
Thread: Brake Shim broken. Do I NEED to replace?
    VX Calais S2
    Mar 2008
    Auckland
    Default Brake Shim broken. Do I NEED to replace?
    Well I took the plunge and fitted some DBA Slots on the fronts of my 02 VX Acclaim along with some "competition" pads I picked up for a song from an online auction.
    When changing them yesterday one of the metal clips in the top of the anchor plate was in 2 pieces. This is the one that appears to be part of the anti-rattle system.
    How critical is this and should I replace it sooner rather than later?
    VY SII HBD Calais L67
    Dec 2006
    IMO anything to do with brakes should be 100%. Are you talking about the thin tin thing that goes from the outside of both pads? Only anti rattle but while you are bedding in you new pads and rotors any vibes can make then more prone to run out down the track. Just my 2c.
    How about some pics?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The metal clip is what locates the pad in the caliper and stops it from moving around. You need to get a new one.
    Visit my Facebook page
    VX Calais S2
    Mar 2008
    Auckland
    Default Thanks for your advice
    I thought as much . Now to track the parts down for a reasonable price!
  1. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  2. Shim size for 308
    By Emski in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-08-2006, 09:32 PM
  3. bxh 136 starter shim thickness
    By FCCOOL in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-12-2005, 09:46 AM
  4. Leaking Master Brake Cylinder Connecting to Brake Booster Advice help please.
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 02:32 PM
  5. How to replace front brake pads?
    By GrpA Calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-07-2005, 05:53 PM
