Results 1 to 19 of 19
Thread: my car still won't run.
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    Default my car still won't run.
    I need help. this issue has been going on for a while, and any resolution i get seems to only be a bandaid fix
    the problem: i get code 46, and obviously the car won't run
    solutions to date:
    CAS was changed with a used (thought to be good) CAS. car ran 100% fro a week, tehn died.
    CAS was again swapped, this time with a brand new CAS. lasted 1 day.
    earth points are tight and not corroded.
    at some point someone helped themself to the fuel, and i borrowed a can to put some in (19L went in can, but 15l showing on dash. (digital shows 15, analogue shows almost half full) it's parked on a hill. can't move it.
    fuel pump makes a noise like it's priming, but i can't be sure as i don't have the tools to disconnect fuel line or a pressure guage.
    up until the most recent attempt, if the battery was left to charge, the car would start. but if left overnight connected it would play games again next day, even though multi shows volts to be within stationary spec.
    this thing's just sitting there rusting and wasting rego. can anyone offer any advice?
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Was there any obvious damage the the CAS's that you replaced?
    MY RIDE
    VR EXEC
    Dec 2005
    quarantine
    nope. i still have both here and they look fine except for a fine smear of road grime
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I thought that perhaps the interrupter blades may have been rubbing on it. Maybe the connector on the loom isn't making good contact.
    MY RIDE
    VR EXEC
    Dec 2005
    quarantine
    DFI CAS and cam sensor connector terminals all look the same, position wise. that was suggested by dr. bob a while back, but when i mentioned that they looked to be fine, he said he'd get a how-to for pulling out teh terminals, but i heard nothing back from him
    VX Executive S2
    May 2006
    Frankston South Vic
    If you are good enough with a multimeter you could measure the signals into and out of DFI module or else If all the connections seem fine try substituting a known good DFI module
    VS
    Mar 2006
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by slappa. View Post
    hav u tried swapping computers with a mates?
    I could be wrong but I don't think that would work because the ECU and the BCM have to be security linked in order for the car to start.
    MY RIDE
    VR EXEC
    Dec 2005
    quarantine
    I've heard the same, but also been told they don't. no mates i can scab an ecu from.
    Quote Originally Posted by lout View Post
    i'm good with a multi, but i don't know what to look for. I know my own car (VR) back to front and upside down, but i'm still learning this car. DFI has been swapped with one i thought was good (from my project l67). would the DFI from my VR work? i know it's fine
    VX Executive S2
    May 2006
    Frankston South Vic
    If you have changed your module it's probably not that
    Have you cleared your codes (disconnect battery for five minutes. Make sure you have your radio code as it will be cleared too)
    Check for good spark on all of your spark plugs
    VY SII HBD Calais L67
    Dec 2006
    Quote Originally Posted by TheForgotten View Post
    Careful, L67 DFI is higher output than L36.
    VR EXEC
    Dec 2005
    quarantine
    cleared codes probly 30-35 times since it started. plugs, will replace ASAP, but i thought if a plug was stuffed it would run, but run like ****
    Quote Originally Posted by chargedvx6 View Post
    are they? I thought they were the same, only the coils were higher output. hmmmm ahh dammit, total brain-fade
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    does it wanna just keep cranking just with no fire? have u checked 4 spark yet?
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VX Executive S2
    May 2006
    Frankston South Vic
    If your module is faulty you will probably have no spark on any plugs ( can be caused by other things too)
    If two plugs don't fire that share the same coil that coil is most likely faulty
    and if just one plug probably lead or plug but it should still start
  15. #15
    VR EXEC
    Dec 2005
    quarantine
    Quote Originally Posted by wrx884 View Post
    yep. no idea how to check spark. timing light?
    coils have been swapped aswell, with no luck
  16. #16
    wrx884's Avatar
    Mar 2006
    I think u need 2 ppl 1 2 crank the car and 1 2 watch 4 the spark? take 1 plug out plug it into a lead, have it near the engine block and crank it over not 100% sure if this is the best way 2 do it tho.
    Its a long shot but ive been postin over n over with similar symtoms that i had a while ago but check the wires behind these looms my car did a similar thing cept i found a wire behind the grey loom that was tapped up managed 2 get water inside and corrode it and eventually snapped it its worth a look? those looms run straight 2 the ecu inside the car
  17. #17
    VX Executive S2
    May 2006
    Frankston South Vic
    Sorry , just reading your BIO are we working on the VR or the VT?
    To test for plugs firing remove one plug at a time and with plug still connected to lead touch plug threaded section against clean metal and have someone else crank engine while you look for spark
  18. #18
    VR EXEC
    Dec 2005
    quarantine
    all well and good, easy to do, but what do you hold it with so you don't get booted?
  19. #19
    VT exec
    Feb 2008
    "fuel pump makes a noise like it's priming, but i can't be sure as i don't have the tools to disconnect fuel line or a pressure guage"
    how about buying the tools..
    check spark as already said also
