Results 1 to 12 of 12
Thread: New key head issue!
    Sep 2004
    Default New key head issue!
    Today went and purchased a new key head which got it programmed to for $75 buks which thought was a good purchase my old key head still works but the rubber buttons got worn out, anyway i went back to my car and go to open my car with new key head and it wouldent open so i was ready to take it back to where i purchased it and got it programmed but i thought i would open my car with old one i still had and then try start the car with my new one so i put in the ignition and started the car up, i then tried the keyhead and was all good it then started working, My question is do they really program keyhead with the old one or the car programs it when u start ur car just wanted to know why it wasnt working b4 i started car?????
    KRUPTD is offline VN BT1 5L
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
    When you program the new key head,you need the old key head.Dont know why it didnt open the doors.Remember VR or VT on wards i think have the 2 stage button.Press the button once and it unlocks the drivers door and then press it again and it unlocks the rest of the doors.Dont know why it didnt unlock...maybe press the buttom properly.
    (KRUPTOR)VN BT1 5L TTB's,MANUAL,LSD
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    The keys from a locksmith are partially programmed by the locksmith using either a working key you have or the BCM security pin number, this program then finalises when the numbers match when its in the car.
    I like my roo well done
    VT
    Dec 2006
    isn't it to do with the rolling immobiliser code (ie. it changes everytime you use it)
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Same sort of problem with the new key I got for the VZ. Cant use the new key and the old key. One cancels the other. So if you use the new key the original wont unlock the car. If you put key in the door to unlock the alarm goes of. Very - VERY anoying. Still waiting for Holdens to have a go at fixing it. Hope on the 60k service they may choose to fix it. Else $120 down the gurgler.
    and 3 Dangerous non ABS VN's
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    Quote Originally Posted by 88GreenVN View Post
    when programmed by a locksmith the key wil not open the doors until it is cycled in the ignition to finalise it, getting a key programmed like this will not "cancel" any other keys.
    not all locksmiths can do VY-VZ keys correctly.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Doctor Bob View Post
    The key was programed by Holdens. It will start the car and run. But then the original key will not open the doors. I'm puzzled by this one. Should I try the keys again out of town so as to not set the alarm off again and bug the people next door?
    Doctor Bob's Avatar
    May 2004
    its possible the key has failed, the programming sequence cannot delete a working key
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    You are not meant to use the new key to open the doors, until you lock the inside doors manually start up the car and let it idle for a few minutes to burn it into the key. Good thing about mister minit is they give you instructions and a code number for your key, in case you ever lose the whole set, they can cut it from the code.
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Weird i got a lock smith 2 do my VTs head key its worked straight away with unlocking the car and locking it again i know this coz the guy walked out 2 my car 2 test 2 make sure it worked. It wasnt inserted into the ignition untill i got into the car n drove off, also my old key head still works on my car.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    88GreenVN's Avatar
    Jun 2006
    Just had the VZ back to Holden. The computer is stuffed and will not let the new key work properly. They have ordered a replacement computer under warranty. Top service from Southgate.
    1995 3.8l series2 vr commodore
    Dec 2010
    mildura, victoria
    with most of the key heads iv been told that u just put the new keyhead into the ignition and switch it to the reds (on position) and wait 30seconds or so and then start the car, thats the programming done! a locksmith did this to a friend of mines car...
  1. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  2. Here's a new one... (VE Issue)
    By CSP in forum VE Holden Commodore (2006 - ?)
    Last Post: 05-04-2008, 05:33 PM
  3. VN HSV +6 issue
    By And_ROOS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2007, 03:25 PM
  4. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
  5. LPG/VT Issue
    By tdub in forum The Pub
    Last Post: 30-05-2006, 07:28 PM
