Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VT - VX Holden Commodore (1997 - 2002)
VT - VX Holden Commodore (1997 - 2002) Talk about anything relating to the VT - VX Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 23-03-2008, 04:56 PM
Ride: VXII Berlina 3.8L
Sam_100 Executive
Default What type of brake fluid?
Hi all,
After a few years of living with brake shudder in the VX, I finally replaced the discs and pads this afternoon. Prior to starting work I removed some brake fluid from the reservior to prevent any spillage when pushing the caliper piston back in.
My problem is that the reservoir is now low on fluid and I need to top it up. Question is what is a suitable fluid to use. I have purchased a Dot 4 brake fluid but don't know whether it is compatible with what's in the Commodore. Holden specs say you should use a HN1796. Can anyone help?
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 23-03-2008, 07:32 PM
vuv6's Avatar
supercheap team member
Ride: 02 VU 3.8L Manny
Trade Rating: (0)
vuv6 Berlina
dot 4 will be fine
__________________
Check out my ride here... VUV6
If i was helpful please click on scales up the top and give me sum feedback!
  #3
Old 23-03-2008, 08:02 PM
RVN 355's Avatar
Ride: 91 VN SS 355
Trade Rating: (0)
RVN 355 Statesman
Go to repco,autobarn or so forth there is a gm specification emblem on the break fluids man,Go A Valvoline Brand one dot 4 will be fine mate if ya got fluid in there atm go dot 3.if ya gonna bleed the system and removed the lot go dot 4...
Performance Super Dot 4 Brake Fluid
Valvoline performance Super DOT 4 is a low moisture absorbing brake fluid designed for all cars, trucks and vehicles fitted with disc or drum braking systems.
Meet all vehicle manufacturer requirements for DOT 4 and SUPER DOT 4 hydraulic brake fuids and is suitable for brakes operating under extreme and heavy-duty conditions. Perfect for use in vehicles fitted with hydraulic clutch or ABS systems where the use of a DOT 4 or SUPER DOT 4 is specified.
Conforms to SAE specifications J1703, Federal Motor Vehicle Safety Standard FMVSS No.116, DOT 4 and Australian Standards AS/NZS 1960.1.95 Grade 3 and is compatible with all non-petroleum (Polyglycol) type brake fluids. Also meets Ford ESZ-M6C55A and General Motors HN1796.
Heavy Duty Super Dot 3 Brake Fluid
Valvoline HEAVY DUTY SUPER DOT 3 BRAKE FLUID can be used in any vehicle where the manufacturer recommends using DOT 3 brake fluid, including ABS systems where DOT 3 is specified.
DO NOT USE WHERE A DOT 4 BRAKE FLUID IS SPECIFIED OR MIX WITH OTHER BRAKE FLUID.
__________________
Cheers.
* RVN 355 *
RVN 355 ALPINE VN SS 355 CUBIC INCH V8 WITH BILLET / CHROME UPGRADES
  #4
Old 23-03-2008, 08:19 PM
Not_An_Abba_Fan's Avatar
Ride: MY08 Outlander XLS
Trade Rating: (0)
Not_An_Abba_Fan GrangeNot_An_Abba_Fan GrangeNot_An_Abba_Fan Grange
It depends on what is in there already, if it is a dot 3, the dot 4 will not mix with it. Dot 4 is specified for high temperature applications, most standard street brake fluid is dot 3.
__________________
It is better to be silent and thought a fool than to open your mouth and prove it.
Quote:
Originally Posted by DannyboyDS View Post
Wholesaler of exhaust, suspension and brakes.
  #5
Old 25-03-2008, 09:35 AM
gslrallysport's Avatar
Ride: VZ AWD One Tonner
Trade Rating: (0)
gslrallysport Executive
Just get what ever is the cheapest dot 4... It *literally* all comes from the same factory in Europe. Same factory that makes some of Dulux's premium paints... oddly enough.
^ And that's why. Its a specification, not a standard, meaning that there's only one place that can make it.
__________________
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
brake fluid flush andyli VN - VP Holden Commodore (1988 - 1993) 12 08-01-2008 05:32 PM
Change Brake Fluid Mr_Slim VN - VP Holden Commodore (1988 - 1993) 3 15-02-2007 02:43 PM
Brake Fluid... Which DOT? VT Dave VT - VX Holden Commodore (1997 - 2002) 3 17-01-2007 07:33 PM
Flushing the Brake Fluid 05 VZ SS General 7 12-12-2006 12:19 AM
Brake Fluid and Auto Trans Fluid. Melchior3 General 4 20-02-2006 11:49 AM
Edinburgh Short Breaks | Web Advertising | MPAA | Credit Cards | Cheap Loan | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
