Results 1 to 4 of 4
Thread: 2000vt sedan question
    Mar 2008
    Default 2000vt sedan question
    My power windows dont work,Each time i try n put my(driver side) window down i can hear a clicking noise from under the dash.Have u people had such problems? Any help is good help and thanks in advance.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Could be a broken wire in the door loom (in the flexible boot that goes from to door to the body) or it could be a problem with the motor. If you can remove the door trim then you could test to see if the motor is getting power. It could also be a faulty relay I suppose.
    MY RIDE
    2007 VE Clubsport
    Nov 2003
    South Perth, WA
    isnt there a black control module under the steering wheel? that mite need replacing no on my vn i had to replace it coz it was doing the same think as wat urs was doin....but yeh not sure of the setup on the vt would think it was similar i dont have power windows on the ute
    cheers
    ryan
    Check out my ride here...E Series Chubby
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by vuv6 View Post
    cheers
    ryan
    The BCM does control the windows but since it is only one window that doesn't work it's best to check the easiest things first, wiring and motor.
    MY RIDE
  1. VS Sedan Spray Question
    By D34N in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-12-2007, 08:19 PM
  2. Ebay question.... moral question?? lol
    By NORTI in forum The Pub
    Last Post: 03-04-2007, 03:43 PM
  3. Will VN Sedan Rear Shockers / FE2 Springs fit into a VH Sedan?
    By VHSLX3300 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-01-2007, 12:28 AM
  4. My 2000VT Berlina
    By mytag5 in forum VT - VX - VU - WH - V2
    Last Post: 13-12-2005, 09:24 PM
