Results 1 to 15 of 15
Thread: Buying VX Manual Clubby... INFO PLEASE!
    Torquen's Avatar
    Torquen is offline Boost FTW
    450+ HP FORD XR6T
    Mar 2006
    Perth, WA
    Default Buying VX Manual Clubby... INFO PLEASE!
    well my VS just packed it in over easter so its new car time, and my weapon of choice has been made, it will be a manual VX clubby.
    im just intrested to know some things to looks out for when purchasing a VX, an LS1 and of course Clubsport. Any help will be much apricated.
    thanks in advance Jesse.
    VY LS1 Berlina Wagon
    Jun 2006
    Dont know if its common, but when we got the VX GTS, the diff has a leak, which my mate didnt get fixed, causing the diff to run out of fluid and cook its self...
    I guess just look for common signs of ware and tare:
    * check all the fluids
    * make sure the cluch isnt slipping
    * listen for any knocks/rattles
    * make sure the disks are in good nick
    * I'm sure all the oil consumption problems were fixed in the LS1 by VX, but you should look in the log book to see if this was a problem.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Yeah, just lift the oil cap and look for nice coloured oil. Get it up on a hoist for sure too! Look for leaks and undercarage damage!
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Call HSV and get a check done on the VIN. Avoid paying good money for a mockup.
    and 3 Dangerous non ABS VN's
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by 88GreenVN View Post
    This is a good point.
    Umai Naa!!'s Avatar
    Umai Naa!! is offline R.I.P APY-88V :(
    VR S1 Exec. A4 3.8L
    Jun 2006
    Sthn H'Lands, NSW, Aust.
    Also check for oil leaks around the power steering pump, smooth idle, rear tyre inner edge wear, LSD operation, too.
    AUS12
    New project. New direction. New Ideas. No money!
    VT/VX Parts For Sale
    VY SII HBD Calais L67
    Dec 2006
    holden007 is offline VRII
    Subaru Liberty
    Dec 2003
    The rear inner tyre wear problem was fixed when the VX Series II came out, to fix on earlier version you need a camber kit.
    Umai Naa!!'s Avatar
    VR S1 Exec. A4 3.8L
    Jun 2006
    It wasn't completely fixed.
    Holden just did a band-aid job of it, by adding a pair of adjustable lateral arms to partially recitfy the poor geometry control, by giving you the ability to adjust the toe, to an extent.
    With the VE's new (old, actually) setup, it chops the outer edges!
    AUS12
    Torquen's Avatar
    450+ HP FORD XR6T
    Mar 2006
    Perth, WA
    is power stearing a known problem with the VX's?
    lol, how do you sugest i test the LSD???
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Quote Originally Posted by Torquen View Post
    Take it for a "test" drive in a nice quiet area.
    EvoVIIIJDM is offline Got Evo?
    Evo VIII JDM
    Nov 2005
    Check it out thoroughly.
    I just replaced my power steering pump, dont know if its notorious throughout.
    Camber kit will be a must, getting mine done tomorrie.
    Get RAA or RAC or whatever it is in your state to give it a check over.
    With a tune and a few bits and pieces, vx clubby lethal machine. GL!
    s_ikari2015's Avatar
    s_ikari2015 is offline Fun IS easier with an 8
    '02 Monaro V2 CV8 6m
    Nov 2007
    Australia
    RAA/RAC whatever are useless. They're mechanics that don't specialise in any particular car and more often than not they don't know what they're talking about with common problems on specific model cars. I wouldn't let RAC check the tyre pressure if I had a Clubsport.
    Power steering tends to leak. My brother's VX had a leak from the reservoir but that was easily fixed. His also developed clutch problems far too easily. I admit he wasn't treading on eggshells when he drove it but his very expensive rims and tyres kept him in check.
    I haven't lost my mind, it's backed up on tape somewhere
    Umai Naa!!'s Avatar
    VR S1 Exec. A4 3.8L
    Jun 2006
    In regards to the power steering, it's either the rack that leaks, the resevoir that melts, or the pump that spits a seal.
    AUS12
  15. #15
    Torquen's Avatar
    450+ HP FORD XR6T
    Mar 2006
    Perth, WA
    ^^^lol, any other problems with it
    thanks for the heads up fellas.
  1. Looking at buying a VS SS 1995 Manual
    By Sambo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2008, 07:25 PM
  2. looking at buying a vs clubby...
    By lumina01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2007, 08:16 PM
  3. Eaton M90 manual or installation info
    By vkberlina in forum General
    Last Post: 11-07-2006, 10:51 AM
  4. Need info out of manual-ANYONE!
    By simoVN88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2006, 04:41 PM
  5. VN Calais 1990 manual ! Anyone with INFO?
    By Hot-Rod in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2006, 01:39 AM
