Results 1 to 12 of 12
Thread: weird a/c sequence
    vt berlina
    Feb 2008
    Default weird a/c sequence
    hi
    i have a problem with the operation on my vt berlina series 1 air /con
    when on face mode it goes to windscreen mode when you accelerate
    when you back off it comes back to the face mode
    i suspect that it is a vacuum problem
    trouble is that i have only had the car for a month and i am not familiar where these things are any help would be great
    thanks
    ian b
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Sometimes, under heavy acceleration, it is normal for that to happen. Often when there is a vacuum leak the main culprit is the thin vacuum hose that goes to the rear of the intake manifold. There is also a plastic valve thing connected to it that may not be working. The vacuum tank is up behind the glove box.
    MY RIDE
    vt berlina
    Feb 2008
    Quote Originally Posted by accentstencil View Post
    thanks for that
    it gives me somewhere to start looking
    cheers
    ian
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    its not normal under any circumstances.
    it is caused by a vacuum leak or lack of vacuum to the actuators.
    check the one way valve in the line under the bonnet, it can also be one of the actuators in the dash or a crimped line in the dash.
    Rob
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I'm sorry for providing the wrong info on it "sometimes being normal under heavy acceleration" but I thought I got that information from a reliable source.
    Once again I am wrong.
    MY RIDE
    VS III S/C 50th Statesman
    Apr 2008
    Ian,
    Did you get this sorted? My 98 VS does the same thing, especially under load. It came back from the AC/ electricians unfixed so unless he has some ideas in a hurry it will be going elsewhere this time.
    Ben
    Doctor Bob's Avatar
    May 2004
    if it happens in floor mode as well the vac leak is in the supply circuit, if its only in face mode the problem will most likely be the actuator.
    Apr 2008
    Helpful info Bob, I think it's to the floor as the redirected air isnt that obvious, rather just the on and off of the face air. Will check, thanks.
    vt berlina
    Feb 2008
    Wink
    thanks for the help guys
    you were right accentstencil , it was the thin rubber line behind the inlet manifold
    for some reason the rubber hose had swollen, and it was not sealing properly
    luckily there is ample length there to cut of the end and fit it back over the nipple , all works well now
    ian
    Apr 2008
    I checked the vacuum hose out of the rear of the manifold of my SC V6 and it seems fine, no cracks or swelling. Now the line splits off, one goes through the firewall and to the controls etc I assume, the other line wraps right around the engine bay edge and disappears down near the headlight. Where does that vacuum hose go? Also, theres a white one way valve looking item on this line, a bit like the valves on the washer nozzle hoses. If this is letting vacuum back through the way it came would it affect the air vent operation? This is still the line that runs off to the front of the car so not sure what it operates and none of this setup is in the standard Gregory's VS manual due to it being a SC motor.
    any ideas?
    thanks
    Ben
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The hose near the headlight is probably going to the vacuum tank. It that valve is not working it will cause problems.
    MY RIDE
    Apr 2008
    Thanks I'll look into this valve and if it may be faulty. Would it have a direct effect on the vent operation as no other hoses appeared faulty or squashed, even had electrician go over it chasing ideas.
  1. dose an 1 no the ignition lead sequence
    By dougs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2006, 08:12 PM
  2. Weird VK
    By Z()LTAN in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-02-2006, 08:56 AM
  3. Upgrade sequence
    By vy_acclaim in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-01-2006, 07:59 PM
  4. What sequence do the spark plugs attach to the coil pack?
    By Daniel237 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-07-2005, 08:13 PM
  5. Strange Aircon Sequence As It Died.
    By brother.robert in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-02-2004, 09:41 PM
