Results 1 to 19 of 19
Thread: Do I have a LSD ????
    VS II
    Apr 2006
    Default Do I have a LSD ????
    I have a VT II Exec sedan 1999 and have NO idea if it has a limo diff or no. Any holden heads tell me if it comes with one stock ?????
    Thanks..
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    No they don't come stock with them. There should be a tag on the diff to tell if you have one.
    MY RIDE
    vy series 2 v8 berlina
    Dec 2006
    Quote Originally Posted by weblst View Post
    Thanks..
    A LSD in a Exec would of been ordered with one from new, or a previous owner has fittted it themselves. Is your VT an ex cop car if it is it will have the 9c1 pack which includes the LSD. Check the tag on the diff it will have LSD stamped on it , or spin resistant stamped on it, or jack the back of the car up & see if the wheels turn in the same direction when you turn them by hand. Cheers.
    Ripcell's Avatar
    Ripcell is offline R8 FTW!!!
    324rwkw MY06 VZ R8 Maloo M6
    Apr 2006
    East Melbourne
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    agree with above:
    If your car does this then you have one!
    We got rep back, yaaay!
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    i have a single legger yet if i full lock and boot it, it will spin both and whip me around and then open up with a big lefty. Maybe has something to do with the manual?? It will spin both wheel on the spot but its not LSD.
    no longer a hoon by association - the commodore is gone
    JD
    VS Berlina
    Aug 2006
    Deep South, SA
    i've always thought if you can get a single to spin both that thats your diff telling you its on the way out???
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    i dont think so, or i would be buy lots of cheap about to die diffs so i could do twin skids lol. a lsd will single leg when on its way out though. i think being a manual you are able to drop the clutch at peak torque so it has enough to spin both and not just open up to one.
    JD
    VS Berlina
    Aug 2006
    Deep South, SA
    hmm maybe my VP isn't LSD then, i presumed because it can spin both its a LSD, now im not quite as convinced. ( its a manual as well )
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    yeh just have a look at the diff and read the tag, will say "use only approved lsd fluid" or something like that. or as said jack up the rear and turn one of the wheels, if the other one turns the same way its lsd if it goes backwards then its single pegger
    vs commodore executive
    Aug 2007
    my vs spins both wheels and it isnt lsd
    project vs wagon...5speed
    vs wagon acclaim
    JD
    VS Berlina
    Aug 2006
    Deep South, SA
    I might have to do that 2moro ( actually today! )
    holden007 is offline VRII
    Subaru Liberty
    Dec 2003
    on the casing it should write 'LSD', my friends VX SS has LSD but only spins the right wheel.
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    Quote Originally Posted by holden007 View Post
    i would say your mates lsd is worn out then.. mine spins both
  15. #15
    dijm8's Avatar
    dijm8 is offline What You Looking At
    VZ SS LS3
    Jun 2006
  16. #16
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    Actually looked at the tag on my diff while i was under the car today.
    It said somthing like, High performance LSD, use specific fluids only or somthin on it.
    Maybe something to look for if ur unsure
  17. #17
    VT
    Dec 2006
    A open diff will send all drive the wheel that is easiest to spin.
    If they are both equally easy, like when going in a straight line, it is quite common for both wheels to spin.
  18. #18
    Subaru Liberty
    Dec 2003
    Quote Originally Posted by BOGANV8 View Post
    I wouldnt be surprised, he blew the gearbox, next the diff!
  19. #19
    Vp calais, gemini
    Feb 2008
    melb, vic
    mates vx is lsd, singles everywere same as another mates 5ltr bt1 vs both cars have irs,
    my vn and others i have seen spins double everywere a good single spinner diff should single but worn ones spin both, doesnt mean its about to **** tho.
    I reckon live axles are better for burnouts!
    vn v6 calais mock up run around,
    vn v6 manual wagon parts car,
    vp v6 berlina lx project car
    vc 186 aussie 4 speed
    vl 6cld wagon
