Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Connecting Fog Lights on a VT S
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Default Connecting Fog Lights on a VT S
    I recently put on a front bar that contains fog lights. I'm just wondering how I go about connecting the lights to a switch in the car as its only a S and didnt come stock with fog lights. Any instructions would be great. Thanks.
    Dan
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The wiring should already be in place so all you really need is a the proper foglight switch and a fuse and relay and you should be right. Check to see if the wiring is in place. Look under the front of the car and either side around where the radiator is and there should be a plug for the lights
    MY RIDE
    VY SII HBD Calais L67
    Dec 2006
    To mount the switch to the fascia you can either buy a new one with the correct hole already in place or remove your fascia and cut the hole for it. The switch has a bezel to cover up slight inperfections in the hole if you cut it yourself.
    There are two spare plugs behind the headlight switch with a dark grey foam pouch on them and black tape. Find the one that fits the foggie switch by fitting the relay and conneting the lights then testing the switch. Both plugs fit but only one is for the foggies.
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Thanks guys, I'll check it out and see how I go fitting it and let you know, thanks. Dan
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Here we go, ripped off the front bar (OMG how easy is it!) and yep two plugs are there for some foggies (weather they work or not is another Q) I'm getting the bar painted at the moment so cant test just yet. I was going to pull the facia off today but got dark too quick. have been reading about how to do it and am confident on getting it done, although I do have 2 questions,
    1) when I get the foggies hooked up will they run off the same system as the headlights, ie turning off when the drivers door opens.
    2) I'm going to have to cut a hole in the facia, whats the best way to go about this?
    and one more.
    3)chargedvx6 said that there are two plugs under the headlight switch, but only one is for the foggies, what the other for? Thanks again guys. its appreciated.
    Dan
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The foggies will turn off when you open the door.
    The other plug is for an option which allows the lights to be on all the time.
    MY RIDE
    98 VT Commodore V6
    Mar 2005
    Briagolong
    awesome, thanks man, one more thing, I didnt really want to fork out $50 for a genuine fog light toggle switch, so I just got a normal toggle switch from Autobarn. i got two, one has a light init the other does not. they both have two prongs, one earth ect, the one with the light has one to power the light, will this work with the plug on the car now? ( I cant check as I havnt taken the facia off yet. Thanks dan
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If you mean will the toggle switch plug into fog light plug, then no.
    Occasionally you can find cheap genuine switches on ebay. Only one there at the moment with an opening bid of $43 or $58.95 buy it now and $10 postage (he's kidding). I have seen them much cheaper.
    MY RIDE
    98 VT Commodore V6
    Mar 2005
    Briagolong
    bugger, can I just use some wire and connect the points? Also whats the bast way to cut a hole in the facia with out cracking it? Thanks,
    Dan
    vr executive
    Oct 2007
    Hi nabed4t.
    I have just fitted the same lights to my Series 1 VT S pac.
    Wiring is all there - only need a $9 relay (under the bonnet) from GMH.
    If you aren't that competent with wiring, I recommend that you buy the genuine switch from Holden ($53) - it's well worth it, even just to avoid the extra wiring hassles with any after market switch.... if you had to pay someone to fit it would cost more than the switch!
    Not to mention it suits the dash and looks like factory fitment.
    The switch only needs a series of tiny holes drilled in the 'oval' shape of the bezel and then can be trimmed with a Stanley blade or small rasp/file.
    You will need to put a 'tell tale' globe in the dash if you want the fog light indicator to work.
    Dec 2006
    Mine already had the globe in the dash but it wasn't activated until I clipped in the in cabin switch and under bonnet relay.
    To the OP, you are saving a few hungie by DIY this job so just get the genuine part for the switch. They are to be had for $25 from wreckers left right and centre or the new stuff isn't that much. At least if you use a bodgy switch don't wreck the fascia to fit it, just cable tie it under the dash out of sight and leave it on. When the headlights are on the foggies will be too.
    VT Executive 98
    Mar 2008
    Queensland, AUS
    I'm lookin to do this to my car soon, ive got a vt exec v6, is there anyway to have the fogs on and not the headlights?
    vn/vp Speedway Street Sedan
    Sep 2005
    Cool
    Quote Originally Posted by chargedvx6 View Post
    Just be careful doing that, i know in queensland it is an offence to drive with your foggies on and it is not adverse weather conditions eg fog etc, expect a fine here..... The boys in blue have really been cracking down on this one due to many people compaining of being dazzled by additional lighting.
    It may be different in your state?
    If unsure google your local transport authorities rules on additional lighting.
    Also there was a previous thread about foggies on here that was fairly in depth if you are interested.
    My advice is go the original type swith and make it look factory. Car will look sweet with your new bar on!
    Good luck!
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Ryan Mckd View Post
    If they are wired properly (as factory) you can have them on without the headlights but the parkers will be on. The fog lights will not turn on with the headlight switch in the off position.
    MY RIDE
  15. #15
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Sweet as, thanks guys, just ordered the relay and the switch from holden, should be in tomorrow! Thanks again for all your help, its appreciated!
  16. #16
    98 VT Commodore V6
    Mar 2005
    Briagolong
    One more thing, I didnt realise that the new bar has a holden badge on the grill...the VT has one on the bonnet right over the grill...how do I go about removing this badge? Thanks.
    Dan
  17. #17
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by nabed4t View Post
    Dan
    They are stuck on, I don't think they have locating pins. Use a hair dryer to heat it up and it should come off easily.
    MY RIDE
  18. #18
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Alas there is a pin. I'll look into getting it off and the hole filled. Any DIY tips on how to fill the hole would be great.
    Also I'm trying to change the cluster from the standard black to a white one, any hints on how to do so would be great, I've gotten as far as I can, I've removed the protective glass and need to remove the needles. i've searched for related forums but can only find very vague details. I need to know is there any risk in removing the needles, will it effect the acuracy of the dials? Thanks.
    Dan
  19. #19
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Ok, I popped off the badge on the bonnet, came off really easily, suprised it hadnt been stolen. All the glue from behind the badge was gone. Only the pins were holding it in place. just a quick question. Is it possible to get the holes filled in or somthing of that nature? Thanks,
    Dan
  20. #20
    VT Executive S1
    Jan 2007
    I also have a VT exec v6 97, will this have the wiring to? Do all Vt's have the wiring come stock?
    So basically let me get this straight;
    There is wiring already there,
    I just need to hook up it up to the foglights
    Buy one of these genuine holden switches for around $50
    then run the wires to my dash and mount the switch?
    Have i missed anything :S
    Computer/Networking Problems? Contact me
    Check out my ride! First car!
    http://forums.justcommodores.com.au/...ad.php?t=49696
  21. #21
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It may or may not be there. Check where the relay goes and if it has connectors for the pins of the relay in the holes, you should have the wiring in place. You can also check under the car at the front, either side of the radiator and see if the plugs are there.
    If they are there, then all you need is the lights, switch, relay and maybe a fuse, no need to run any wires.
    MY RIDE
  22. #22
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Yeah mate thats all you have to do, $9 relay from holden, use the relay diagram under the bonnet to find where the relay goes, plug it in, in the dash, right under the headlight switch behind the facia there "should" be a plug wrapped up in padding and tucked away in a recess, just unwrap it and plug it into the fogy switch, (after youve mounted it) and away you go.
    One more thing, the plugs on the front of the car may need a clean, they arnt covered and as a result are exposed to the element dirt and alot of crap get in there. just check so you get a clean connection. Good luck with it!
    Dan
  23. #23
    VT Executive S1
    Jan 2007
    Where abouts does the relay go? I am confused :S
    If you check out my ride in my sig, i already have fog lights on my monaro bar, i just need em hooked up.
    Dad said he was gonna get a auto elec but i started reading here and if the wires are there it wont be complicated at all because im alright with electronics/wires
    Whoops, posted this JUST as i got the email saying nabed4t wrote that ill check it out now before work.
    THANKS MATE!
  24. #24
    98 VT Commodore V6
    Mar 2005
    Briagolong
    Pop the bonnet, on the left hand side just behind the battery should be a black covering, pop that off and the relays go there, use the diagram on the back of the box to see where the fog light relay goes.
    Dan
  25. #25
    VT Executive S1
    Jan 2007
    Yup ive got a relay in there, what happens now. where abouts should the wire be for the foglights?
    And i assume there already would be a wire run through to the dash/facia?
  1. Connecting a neon to where the interior/boot light would go?
    By VS Omega in forum Electrical Wiring / Questions
    Last Post: 03-08-2006, 01:33 PM
  2. sparking when connecting battery
    By 90VN55 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2006, 05:53 PM
  3. Dis-connecting immobiliser
    By Just_Ice in forum Electrical Wiring / Questions
    Last Post: 19-02-2006, 06:41 AM
  4. Connecting boost gauge to VS
    By VSSleeper in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-09-2005, 02:26 AM
  5. Connecting Nokia CARK 91 to radio speakers
    By Kabe in forum Car Audio
    Last Post: 01-07-2005, 08:57 PM
