Results 1 to 10 of 10
Thread: Handbreak warning light(and sound)
    Series II VE SV6
    Feb 2008
    Default Handbreak warning light(and sound)
    I need a some help.
    A couple of days ago when i took my hand break off the light stayed on i put the hand break on and off again and all was fine but now its gotten a hell of a lot worse now in the middle of driving the light comes on and i get the annoying hand break on beep and light. Is there an easy fix for this?
    Swordsy's Avatar
    Swordsy is offline mmmm beer....
    VUII Maloo R8 - XJR1200 - XR450R
    Nov 2007
    Newi NSW
    Series II VE SV6
    Feb 2008
    ? I'm clueless, your gonna have to give info on how to check these things aswell
    BTW my dad seems to think it may have something to do with me putting the hand break on to tight which i find it interesting him telling me that now as when i was on my L's(3 months back) he would bitch at me for not putting hard enough.
    s_ikari2015's Avatar
    s_ikari2015 is offline Fun IS easier with an 8
    '02 Monaro V2 CV8 6m
    Nov 2007
    Australia
    definitely sounds like the switch might need adjusting. Usually the only other thing is low brake fluid pressure which will also set that alarm/light off. You can rule that out though if the brake pedal isn't spongy and it doesn't take a whole lot of pedal movement to get the brakes working.
    I'd say, if your brakes are functioning normally, only just needing to touch the pedal, and the brake fluid level is fine then it would be a dodgy switch under the hand brake lever. Easiest solution is take it to Holden.
    I haven't lost my mind, it's backed up on tape somewhere
    Series II VE SV6
    Feb 2008
    I think i found the problem, i just looked under the hand break cover and found 20c
    I'll go for a drive a bit later see if it did the job but i couldn't get it to mess up in the drive way.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    That was a cheap fix and you gained 20 cents.
    MY RIDE
    pmlegend's Avatar
    pmlegend is offline pmlegend
    VS Series 2 Wagon
    Dec 2009
    Collarenebri
    You wouldn't believe it but I had a similar problem today with my VT. Brake warning light staying on and annoying sound as well. read this thread and decided to check and there was a 20c piece stuck down there.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by pmlegend View Post
    Those coins can be a problem, I couldn't open my fuel cap cover due to a 5 cent piece.
    MY RIDE
    VTCommy is offline up tha commodores!
    VT Executive S2
    Dec 2008
    Streaky Bay
    haha well i had a 50cent peice in my handbrake which was stopping it from going down all the way and about 75cents worth of coins in the cd player! great little nephew isnt he haha
    VT Calais
    Mar 2009
    SA - Victor Harbor
    lol i had exact same problem although mine wasnt money, you know the map lights how they have the metal cover thing over them, well when i bought my vt calais 3 years ago, the globe was blown went to change it, and that metal cover fell out and i lost it, looked for ages and gave up, over a month ago now my hand brake did the same thing, i thought the switch inside the handbrake cover straight away so i took it off and sure enough there was the metal cover for the fog lights haha
  1. Alternator Warning Light & ABS OFF Light
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2007, 10:10 PM
  2. Tail light warning light
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-08-2006, 06:27 PM
  3. Tail light Warning light
    By G4orce in forum Electrical Wiring / Questions
    Last Post: 26-07-2006, 08:15 AM
  4. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
  5. VZ dash fog light warning light
    By Torquative in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-08-2005, 07:13 PM
