Results 1 to 13 of 13
Thread: troubles starting/abs light/codes = :(
    2000 VX Calais 3.8L Supercharged
    Jul 2006
    Default troubles starting/abs light/codes = :(
    help! ive got a few troubles hopefully someone with some helpfull info might assist me
    first things first, ever since i got my injectors reco'd my car hasnt been starting on the first crack after the turn of the key. it usually takes 1-2sec as apposed to being instant before i had the injectors done.
    next, started the car up one morning, and the (!) light came on, i thought nothing off it when i started it and drove to work. (apparantly NONE of my brake lights were working on the way to work as a kind informative yet angry driver by yelled to me) after 15 minutes the (!) light went away and ABS light, trac off, low trac and airbag light all come on...AND my power steering went all very heavy (i can still steer with it, its not like when u loose all power)
    this has happened about 1 week after i put a whole new alternator in and everything is tight (my old alternator fried itself while i was driving to pick up a new one lol)
    ive pulled the codes
    31 - theft deterrent signal missing (cleaned key reader + key)
    92 - low speed fan fault (i cleaned the relay with crc)
    95 - trac control signal (out of range) ???
    Vt 5Ltr Executive
    Mar 2008
    Albury
    hey mate, me car has sone everything exsacaly the same, i have a massive delay with the car starting i have to turn the key normaly 3 times on and off before it starts, like the fisrt two times i try nothing happns, like no battry is connected or somthing.
    and my air bag light goes on and off when it feels the need
    Jul 2006
    yeah, but they didnt remove any electrical's when they did the injectors as far as i know, ive changed the fuel filter twice since i got the injectors done, maybe coincidently the pumps **** itself lol
    anyone know what the standard price for an auto-elec to chase a bad earth perhaps? would they need a car for a few days lol?
    also any decent auto elec's/mechanics out north eastern melb (greensborough way) ? every one i talk to has no idea what a factory s/c v6 is
    VY SII HBD Calais L67
    Dec 2006
    I think your battery in the key head is flat. It sets off all kinds of crap. Better off getting a new one b4 you get stranded and it won't let you start the car at all.
    Jul 2006
    i give up, my lock cylinder just **** itself after i got home thank god, i can turn the car over contacting the key contactor, and turning the key with a screwdriver now :/
    Dec 2006
    Dec 2006
    The ECU powers down everything and acts like the car has no power. It just turns everything off and the more you try, the more it shuts down. GM immobiliser at work.
    KRUPTD is offline VN BT1 5L
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
    Being a VT those codes that were thrown such as code 31-theft detterent signal missing (is a common fault code thrown) and code 92 Low speed fan fault (is a common fault code thrown) these codes i wouldnt worry about because every VT and VX that come into work that we put our machine on has either both of these codes logged or one of them.And our guys that we deal with st service solutions(efi specialists) in QLD who sold us our scan tool have mentioned that these codes are a common thing but nothing major to worry about.Maybe you have a problem with your BCM should get your computer checked for faults.
    (KRUPTOR)VN BT1 5L TTB's,MANUAL,LSD
    Jul 2006
    Apr 2008
    Hey this is a little off topic but does any one know how to tell if my 97 VT executive has ABS. I have to change the FL wheel hub and need to know if my car is fitted with ABS.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If you look at the front of the master cylinder, there should be a module with a heap of brake lines coming out of it, if that is there, you have ABS.
    Visit my Facebook page
    Apr 2008
    Default Abs ?
    thanks for the reply man. I havent checked under the hood yet. But i do have a ABS light on the dash at startup so i would assume i do. But i just want to make sure before i spend 200 on a bearing. Can anyone confirm im right.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The ABS light is on all models but it doesn't light up unless you have it.
  1. Starting troubles
    By jiff in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2008, 07:17 PM
  2. light troubles
    By statomatic in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2007, 01:58 PM
  3. Engine light on, cant check codes
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2007, 09:45 AM
  4. How do you get engine light to flash codes?
    By andy05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-04-2006, 12:51 PM
  5. Starting probs - Engine light on.
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2005, 10:07 PM
