Results 1 to 12 of 12
Thread: Replacing Diffs
    May 2004
    Default Replacing Diffs
    I bought a new diff and just wondering how hard would it be to replace this myself? Would it be necessary to remove the whole IRS cradle to get to the diff? Is there enough room to get a socket onto the bolts holding the diff with the cradle still in the vehicle? Any tips and advice appreciated. Also how much should I expect to pay a mechanic to do this for me?
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    Disturbed_vegeta's Avatar
    Disturbed_vegeta is offline I'd Prefer To ROAR!
    Vs Statesman, Vr Senator 185I
    Dec 2005
    Burpengary
    umm im picking a lsd for my vs tomorrow^_^ and hopefully it wont be too had just bit woried about droping the orginal diff onto my arm or something like that after i unbolt it lol. but if all goes to plan i will most likely post a how-to^_^.....will i need to change the oil or anything like that?
    Aug 2005
    Mt Martha, Vic
    Changing the oil is always a good idea man, make sure you get the good stuff for an LSD
    Dec 2005
    Burpengary
    Quote Originally Posted by Wagon_Wheel View Post
    i got a 20ltr drum of the good stuff here...so would i just tip the old stuff out and pour the new stuff in then bolt the diff in?
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by Disturbed_vegeta View Post
    is it irs or live axel? if it non irs and once you pull the shafts outs, you will need to remove the shims spacing the diff, then you will have to lever out the centre, when you put it back together make sure you put the shims back in the right way
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Dec 2005
    Burpengary
    Shounak's Avatar
    Shounak is offline The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    There's a plug. Or you could even just open the housing and replace the gasket.
    Shounak
    Always Right
    My Ride
    Dec 2005
    Burpengary
    Quote Originally Posted by Shounak View Post
    yea but how much would i have to put in...also after just looking under my car i noticed that the rubber sleve thing that covers where the pole looking thing to the center has busted and theres grease up on the chassis etc from spinning around. is this something to really worry about?
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    You should get the boot replaced. Either take the car to your mechanic or buy a service manual that will give you a step by step instructions on fitting it.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Shounak's Avatar
    Apr 2005
    There are two plugs/bolts. There's an oil checking one and oil draining one. Keep filling up til the oil's filled to the height of the lower plug. You will need an oil pump to do it, or you can rig up some contraption.
    Otherwise, find out the diff oil filling capacity from a workshop manual or similar. I don't have mine handy, but some good samaritan might.
    Changing diff oil is very easy, but oft neglected.
    Shounak
    Always Right
    My Ride
    Dec 2005
    Burpengary
    well turns out i have to replace the center lol so now i will have to fill the diff up with new oil...i got a oil pump btw, i will check it all out tomorrow.^_^
  1. Diffs
    By davebart25 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2006, 02:55 PM
  2. Diffs
    By Murdoch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-04-2006, 07:40 PM
  3. Diffs
    By tr3nt in forum General
    Last Post: 17-04-2006, 08:47 PM
  4. Diffs...
    By tropical^fish in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-12-2005, 06:00 AM
  5. diffs
    By commnz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-07-2005, 10:23 PM
