+ Reply to Thread
Results 1 to 5 of 5
Thread: Removing Door Strips
    vxsenator's Avatar
    vxsenator is offline I just want one vxsenator Executive
    VT/VX SENATOR
    Mar 2005
    Default Removing Door Strips
    What is the best way to remove the strips off the doors on the base model commodores?
    By taking them off will it remove paint?
    HSV vs FPV
    Camotec Guest
    The strips are held on by double sided tape so removal is easy. get either dental floss or fishing line and put it between the door and the strip and do a sawing motion till it comes off. Remove any left over tape or residue with Wax and Grease remover and then rinse with water.
    Removing the strips will not remove paint as long as you dont pull the strip off by force (and even that generally won't affect the paint)
    Ben
    chirpies Guest
    if you mean the stripe on the outside... you can just pull them off. Park your car in the sun and then pull it off gently, wash off all the crap it leaves behind
    vxsenator's Avatar
    VT/VX SENATOR
    Mar 2005
    Took a few layers of skin off my fingers trying to do this.
    Then I went to Holden and they said to buy a 'Caramel Wheel' to take off all the sticky crap. Whack it in your drill and start rubbing back, its like a rubber circle that rubs back all the tape and silicone ect.
    $17 and my car looks great
    HSV vs FPV
    vxsenator's Avatar
    VT/VX SENATOR
    Mar 2005
    I got quoted $306 for all 6 vx acclaim door moulds from Holden.
    **** me what a dead set rort Holden are.
    HSV vs FPV
+ Reply to Thread
  1. Removing door/guard strips VR/VS
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2007, 08:51 PM
  2. Help removing plastic door strips
    By dean_jely in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-11-2007, 08:34 AM
  3. Removing Strips off side off car!
    By finnbe in forum VT - VX - VU - WH - V2
    Last Post: 29-08-2007, 09:37 PM
  4. Removing door side strips
    By karlos_1984 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2007, 10:40 AM
  5. removing berlina/calais door strips/trims?
    By phat_com in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-01-2007, 04:02 PM
