hi all ive just got a vt sedan 2000,and i was told this morning that my left hand side brake light does'nt work,so i pulled up at work and checked it out walla!! i noticed 2 phillip head screws to take the light out to replace is that all i need to pull out cause i had a look behind and there's nothing else holding them in.
Im sure there's people here who've changed a rear tail-light bulb on a vt sedan?? Thanks in advance.
thank you accentstencil and 20 read this post......
apart from the two screws matey its secured at the front of the light with press stud type things so the lense needs to be pulled away from the car at the front to release these things of course after you have take out the two screws first
