Hi Guys, Mt VT wagon runs 235/45/17's the rear wear evenly everytime however the front drivers side scrubbs out on the inside edge very quickly, have had 2 wheel alignments and doesn't seem to improve anything the passengers front wheel wears evenly. Any ideas?
Thanks Dave
haas your front end been checked out lately?
We got rep back, yaaay!
the only thing that i have been told is the castor bushes are worn but they wouldn't affect camber
OK , get a mate to drive your car at about 5 kph then hit the brakes but don't take his foot of the pedal . Have a look at the gap between the front of the wheel arch and the tyre , then get mate to take foot of brake pedal and see if the front wheel moves forward , It will only move a couple of mil.If it does you need to replace your caster bushes. These bushes have fluid in them and tend to leak .so under cornering and braking you get excesive toe out which wears out the inside edge.I replaced mine with Nolathane units $180.00 a pair . Takes about an hour and they come with spacers which is good if you have lowered suspension . P.M me is you need any info . I took some pics to do a " How to " but haven't got around to doing it .
Happen to me same my size is 235/45/17 front is camber is okay rear camber too bad twice time i replace tyres rear and i went to pedders shop to fix and add rubber somethings and my car rear is pertect cmaber stright no rough it pertect no need replace tyre for 3 yearsi see many many vt or vx problem rear camber because they have no idea hehe.
CHECK THIS PERTECT SHOP. CAN ADJUST FRONT AND FIX REAR.
Pedders Suspension - Straight advice, specialists you understand and... No Bull
#1 VT 1997 Australia TV :
http://www.youtube.com/watch?v=HnvJHLX197Q
#2 HOLDEN HISTORY TO NOW INFO:
http://www.southgate.com.au/history.htm
#3 VT PROBLEM REAR TYRES ALL THE TIMES??? CAMBER,CASTER,TOE TO FIX HERE:
www.pedders.com.au
#4 GOOD ONE PARTS BETTER THEN PEDDERS SHOP:
http://www.nolathane.com.au/products.htm
#5 TO MAKE POWER,INTAKE,COLD AIR "BIG MOUTH":
http://www.ssinductions.com.au/vtvxv6.htm
#6 EXTRA PARTS ADD UP HOLDEN VT:
http://www.allcrashparts.com.au/
happen to me 235/45/17 my rear tyres be worn twice times i replace tyres that why the camber problem rear , so i went to shop call peddle they fix my car rear then 3 year ago to now my rear tyre is pertect.all vt-vx has problem read camber always i drive many i see vt rear camber problem yep
www.pedders.com.au
Its happening , Just be patient lol
stop singing the praises of Peddle Bull vt98green
they su(K rip off b4stards!
