Results 1 to 11 of 11
Thread: Brake problem
    VT Executive 98
    Mar 2008
    Queensland, AUS
    Default Brake problem
    Hey guys, i have a vt executive, and when i put the brakes on it sounds like a aeroplane, sorta a airry sound, hard to explain but if anyone knows what im talking about please give advice.
    Hot-Rod's Avatar
    Hot-Rod is offline SuPaFlY -LiV3 Surviv3 Di3
    VX Commodore Series 2
    Sep 2005
    Oz
    ahh high pitch grinding noise? like squeeky ? its normal. Might have stuffed brake pads or rotors, or the compound on the brakes is making the noise which is normal.
    I have fairly newish brakes and rotors and still make squeeky noise, u can hear the brakes before u even see my car coming haha.
    VT Executive 98
    Mar 2008
    Queensland, AUS
    Nah its not squeeky, it's like a airry noise and my brake petal isnt very firm, mite have something to do with it? i got no clue lol
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    your outta brake's ,digging channel's in the rotor's.
    replace pad's asap.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    VL 5.0
    Dec 2007
    your caliper might be seized as well check that the sliders arnt stuck take em out clen em and re grease them if they are stuck
    VY SII HBD Calais L67
    Dec 2006
    Apr 2008
    Default Abs ?
    Hey this is a little off topic but does any one know how to tell if my 97 VT executive has ABS. I have to change the FL wheel hub and need to know if my car is fitted with ABS.
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by Beet View Post
    yes it does have abs
    Powered By Garrett
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Look in you engine bay on the drivers side, near the brake master cylinder, if there is a squarish thing with about 6 thin metal pipes coming out of it, then you have ABS.
    MY RIDE
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by burnz View Post
    Not all VT's have ABS, it was standard on Calais and Berlina, but exec's was only an option.
    Visit my Facebook page
    s_ikari2015's Avatar
    s_ikari2015 is offline Fun IS easier with an 8
    '02 Monaro V2 CV8 6m
    Nov 2007
    Australia
    The EASIEST way to tell if you have ABS, which my 98 VT executive doesn't, is to open the Fues box in the engine box. Under the lid is a diagram of each fuse/relay. There should be a big fuse/relay labeled ABS on the picture, if it's missing from the bay then you don't have ABS. If it's there then you can test it works by going 60kms/h and then slamming on the brakes and try to lock it up. It should give you a pumping shudder.
    An aircraft noise coming from brakes does usually mean it's metal on metal. Sounds like an aircraft cooling down/braking when landing?
    I haven't lost my mind, it's backed up on tape somewhere
  1. VN Brake problem?
    By Shifty1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-01-2008, 12:53 PM
  2. brake problem
    By Matt_vp in forum V6 Development And Modification
    Last Post: 06-01-2007, 06:15 AM
  3. Brake problem
    By c_dowlo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2006, 01:51 PM
  4. Brake Problem
    By FINCH in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-02-2006, 12:37 PM
  5. Brake problem
    By tkaragia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2005, 09:42 PM
