Hi All
The vent fan inside my VT no longer works at all.
One day i was enjoying the cold air from the air con then all of a sudden it stops working. The air con is still kicking in and out but the fan wont blow the air around.
I have checked the fuses and they seem to be ok.
So i am guessing the fan motor has packed it in.
Has anyone else had this problem and if so how do you remove and replace it??
Cheers in advance
yep the fan itself has died out ull have to replacer it which is behind the glove box compartment, try ebay for a second there about 50 bucks!
