Results 1 to 2 of 2
Thread: Vibration Problem - Shaft Bearing??
    Vu Ute
    Apr 2008
    Default Vibration Problem - Shaft Bearing??
    I just had my shaft centre bearing replaced due to the rubber dust boot splitting. They said they balanced the shaft but I now have a severe vibration at 100km/h +.
    It's an SS ute so the shaft has vibration couplings at each end and the centre bearing in a rubber mounted frame.
    Before I take it back to them I thought I would ask if anyone has any ideas about what they might have stuffed up.
    Thanks
    Steve
    vn/vp Speedway Street Sedan
    Sep 2005
    Check the bolts are tight on the diff pinion flange. Also make sure that all bolts are the same length and have the same amount of washers as each other.
    Other than that it could be that the shaft was not balanced properly or that it could have a bend in it.
    Good luck!
LinkBacks (?)
  1. 30-04-2008, 09:30 AM
  1. Balance Shaft bearing reco
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2011, 06:01 PM
  2. Center drive shaft bearing
    Last Post: 20-02-2010, 09:09 AM
  3. balance shaft bearing
    By Torniquet in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2008, 12:03 PM
  4. balance shaft bearing??
    By revhead1988 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2006, 06:19 PM
  5. how to replace tail shaft bearing
    By crouchy69 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2006, 05:39 PM
