Results 1 to 5 of 5
Thread: Suspension shot!!
    '84 VH SLE
    Mar 2006
    Default Suspension shot!!
    Hey guys, haven't been here for a while but i now have a problem...
    The front suspension is shot in mt VT, it bounces like there's no tomorrow. I have King SL's on standard strut towers.
    I heard all you have to do is dismantle the strut, get the spring out, then buzz a bolt out and take out the shocker, and just replace the shocker, as opposed to replacing the whole kit and caboodle.
    IS THIS TRUE?? And how hard is it to do?
    Cheers in advance.....
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    If its bouncing... you need a new strut... relpace that and your back on the road.
    Not all that to do... there was another tread on suspension a couple down and taking the front apart was talked about.
    Good Luck
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yes, fairly straight forward to do. You will need to remove the whole strut assembly from the vehicle, spring included. The new strut will need to have the spring and top mount swapped to it, then refit to the vehicle.
    Visit my Facebook page
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Can you fit a new strut cartridge like you can to the Vn VP or do the later models have a different set up ?
    Nissan Patrol GU II
    Apr 2008
    Adelaide, SOUTH AUSTRALIA
    No. The strut assembly is combined with the shock absorber.
    If the vehicle is considerably low already then it may be possible to replace the strut without using spring compressors.
    It's worth replacing your upper strut bearings now while the suspension is apart.
    Becareful of these bearings when refitting the strut assembly as they are mainly constructed of plastic and when pinched it breaks.
    You are also 'supposed' to replace the strut bolts and have a wheel alignment check performed after the repair.
    Better the Devil you know!
  1. Holy Shot!
    By Sphinx in forum Jokes/Humour
    Last Post: 23-03-2007, 09:20 PM
  2. Fuel pump shot???
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2007, 10:31 PM
  3. My 1st shot at PhotoChoppin....
    By Frandy in forum General
    Last Post: 23-11-2006, 06:53 PM
  4. Pissing in a shot glass
    Last Post: 29-09-2006, 04:35 PM
  5. can someone post a rear shot of their S-Pac
    By S-Pac_Sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2005, 05:06 PM
