Does '97 VT stud pattern suit '95 VS ?
Cheers Graeme
if you mean are the stud patterns the same on a '97 VT and '95 VS
then, yes, the are the same.
Cheers!
Graeme
Graeme, the same stud pattern goes back to HQ series, 1972.
Pablo
No it doesn't. HQ-WB were imperial, 5 on 4.75" (120.65mm), Commodore went metric, 5 on 120mm. They are close but not the same. While the wheels may look OK bolted on, they will bend and break studs if interchanged. The offset is different too.
But to answer pogmahon's question, yes, VT rims will fit VS.
Well, I don't doubt your specs at all. What led me to believe this is that I have bolted up my VT rims on to my trailer which carries HQ rims to check there suitability so I don't have to carry a separate spare.
Pablo
if i remember correctly
VB-VZ have the exact same stud pattern, 5x120mm.
sorry to bring up an old thread, but i need to ask that this means VT - VZ commodores have a wheel stud pattern measurment of 5 x 120mm? am i right? so if im after 2nd hand rims they should measure 5 x 120mm...?
i want to know that is ford xr6 18 inch wheels fit into commodore vt . i think they would coz they have also 5 stud pattern .
Have a read of my thread on wheel PCD,just click the link below. This will tell you what fits what,what can interchange etc. I will be updating it further as more info comes to hand
Complete(well almost) wheel PCD reference
A pessimist is a man who thinks all woman are bad. An optimist is a man who hopes they are
