I'm wanting to change my cluster from the black to a white, and thought that I better read up on what I need to do as I need to remove the pins to get the cluster out. First do the pins just pop out, I read that someone just used a fork... also when I put them back on how to I go about making sure they are accurate?
I read that there is a test using the method, holding to up and mode button and and starting the car and scrolling through till you get to the all on menu, I go to this but nothing happens, a while ago I was playing with the computer and did the mode and down button thing and changed somthing, there was a set of number like, FFd6001 and you could scroll through them...I changed them and for the life of me I cant remember what they were originaly set on!!! Any help on any of thoes matters would be great. Thanks.
Dan
You can't change them on VT, you probably scrolled down to the next item
sorry? cant change what?
