i got a VxSs and just got a cat back exhaust its in 2pieces! i was wondering can i fit it my self ? after the two middle mufflers the exhaust slips in two one piece does it have to be spot welded or just pushed in??? the red arrows shows where its slips together thanks guys
A lot of those need spot welding, even if it's just for a cat back. Plus there's quite a bit of tweaking to be done to get it right. It won't fit perfectly if you just bolt it on.
You're much better off paying an exhaust place to fit it.
thanks mate was going to do that just wante to see ifany one done it thanks
yeh id say wat shounak says.
RAJAB RACING
FullBOOST
PRESTON AUTOMATICS & DIFFERENTIALS
etstreet.com
They should bolt straight up, they are made in a jig. Unless it has been hit and bent, you shouldn't have any problems. The slip join is held together by single bolt band clamps.
