Hi All,
hoping someone has some info for me, when braking on a smooth road the brakes seem perfect - no pro blem what so ever, but when braking over any bumps/crappy roads etc and applying any sort of decent pressure it feels like that the pedal sinks and i cna kinda feel the braking through my foot(hard to explain) any ideas??? is it normal????
It’s a little hard to go by your description but if I was to take a guess I would say you are activating ABS.
If you get the same sensation when you’re on a smooth road in the wet as you do on an uneven road I would say that it is the abs engaging and you will feel a pusling or vibrating sensation through the pedal.
The uneven roads reduce the available traction to the vehicle to use for heavy braking.
Jezz
