Results 1 to 8 of 8
Thread: Navman keeps blowing fuse
    VZ Lumina
    Jun 2006
    Default Navman keeps blowing fuse
    Hey
    I own a 2001 series 2 S pack Holden Commodore. I just bought a GPS Navman and installed it in my car. But for some reason whenever i connect it to the cigarette lighter for power. It keeps blowing the cigarette lighter fuse. I have to keep replacing the fuse with a new one over and over.
    Does anyone know the problem and what i could do to fix this. Thanks alot guys
    vn/vp Speedway Street Sedan
    Sep 2005
    Cool Try This
    Try plugging something else in to the cigerette lighter that will draw a reasonable amount of current and see. If you have a small handheld spotlight etc, give that a go and see how it goes. If not try something smaller and see what happens eg. Mp3 etc. I would not imagine that the GPs would draw that much actually, but if it blows a fuse when you plug something else in, it is your circuitry to the lighter socket. Also try your navman in another car, go for a decent drive and see if you have any dramas. Same thing, if you blow a fuse you know that you have a problem with the GPS. If this is the case make sure it is not twisted wires inside the plug that goes into the cigerette lighter. May just have 1 small stray wire almost touching between the terminals.
    Good luck! Keep us posted!
    How old is the GPS?
    What is its rated current draw??
    dijm8's Avatar
    dijm8 is offline What You Looking At
    VZ SS LS3
    Jun 2006
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    thats alot fo current to run thru 20 amp wire creates alot of heat ad still might not fix the problem....
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Try it in a different car and see if that car does the same thing?
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    VS wagon
    Dec 2007
    Quote Originally Posted by dijm8 View Post
    cudnt u just put in a bigger fuse in?? say like 25 or 30 amp,
    Yeah if you want to risk a fire
    Fuses are there for protection and blow for a reason
    Fekason is offline Fekason
    MY11 VE Series II SV6 Manual
    Mar 2005
    Penrith NSW
    Default Similar Problem in VS
    I had a similar problem in a vs, but not a VYII. I have also seen it a a WM Statesman.
    The fuse has blown when the plug in the cigarette lighter socket is moved or bumped. The problem would almost certainly be in the lighter socket or wiring.
    feg
    feg is offline
    VT S S/C
    Jul 2006
    Is your cigarette lighter loose? I had a similar problem, with my sunroof. Every time i plugged in my mobile phone charger, the fuse would blow, then the sunroof would close...
    I know really odd!
    turns out they wire the sunroof through the cigarette lighter, but all the nut on the end of the cigarette lighter ( inside the freaking dash) was loose. I could feel this when I plugged in the mobile charger.
    Solution, I pulled apart the dash tightened up the nut on the back and it has never happened since. takes awhile to get to it but you have the chance to do a good vacuum, for all the crud that has fallen in there as well!
  1. My car keeps blowing fuse
    By bellasmummy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2008, 06:24 PM
  2. A/C blowing fuse VP
    By twasm6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2006, 07:29 PM
  3. fuel fuse blowing
    By adzo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2006, 02:50 AM
  4. VK blower fuse blowing
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-09-2005, 07:59 PM
  5. tranny fuse keeps on blowing???
    By TorquemonsteR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2005, 08:19 PM
